April 23, 2018, 02:33:00 PM *
Author Topic: Airbag  (Read 1227 times)
sundezz
you only live once
« on: July 15, 2011, 11:37:23 PM »
Hi i have a 72 mci 5b, front left side airbag
has a slow leak I do have 2 airbags one is
9 inches across in diameter & one is 6 inches,
are the fronts smaller then rears? btw these came
with bus , and what would be the part numbers be
for the front airbags, also have the brass rings and bolts
sundezz
you only live once
« Reply #1 on: July 16, 2011, 12:21:12 AM »
Dug a little more found these bar codes
part # 2b9-240  part #2b12-340 good year
double convolution air spring. is this the correct
airbags that i would need for the 5b? thank you
« Reply #2 on: July 16, 2011, 07:27:53 AM »
You have to go under the bus, after blocking it up safely, to look at what you have. There will be model/part numbers on the bag that needs replacing. You can measure also. One of your spares from the PO is likely the one.
Blackie AB
« Reply #3 on: July 16, 2011, 07:29:46 AM »
Also update your profile with your location so we can help you with a supplier.
Blackie AB
« Reply #4 on: July 16, 2011, 07:45:28 AM »
The fronts are smaller than the rears on a 5A.  Sounds like you have a spare for the front and rear.
sundezz
you only live once
« Reply #5 on: July 16, 2011, 07:46:20 AM »
thanks JC.  I think the po had the right airbags, will
do the blocking 4 sure, btw the you have a beautiful
5C,  I have seen the bus you have the po was in E town
a few yrs back and was given the grand tour, was a beauty then.
your a luck man. I never heard or knew it was up 4 sale  i
remember telling the po owner if he ever wanted to sell to give me
a heads ups . but alls good thats life ...Ed
thomasinnv
Derrick Thomas
« Reply #6 on: July 16, 2011, 07:49:37 AM »
the smaller one is for the front, larger one for the rear.
those are goodyear numbers. MCI # for the front is 12c-1-35, or GMC #2292367 (60.11 ea. @ mohawk)
Rear= MCI # 12c-3-51, or GMC # 2292372 (67.27 ea. @ mohawk)
1998 MCI 102-DL3
Series 60 11.1/Alison B500
