February 17, 2018, 03:54:59 PM *
Author Topic: 1986 eagle 15  (Read 1795 times)
redbusnut
« on: October 02, 2006, 08:52:22 PM »
Where do I charge with shop air.Thanks lb
white-eagle
« Reply #1 on: October 03, 2006, 04:16:05 AM »
my air connect is right behind the passenger side duals.  Batteries, off switch, used to be dump handles, and the air connection.  i assume the air goes in as well as out, just depends on the pressure.  but i am definitely not the expert.
Tom
tomhamrick
« Reply #2 on: October 03, 2006, 09:46:10 AM »
Don't know about the Model 15, but the Model 10 has a place just behind the Eagle tag on the front between the headlights. This was placed there when towing, the brakes could keep air from the tow truck. I assume this is still available on the Model 15.
Tom Hamrick
1984 Eagle 10S
Tom Hamrick
1991 Prevost H3-40 VIP
1981 Eagle 10
Forest City, NC
David Anderson
« Reply #3 on: October 03, 2006, 11:05:39 AM »
I tapped mine in the skinner valve line.  Mine is upstream the tanks though I'm not sure if it is upstream of the wet tank without crawling under and looking.  Install an air/oil separator on your compresser when you do this.  Helps keep the air clean and dry.  I don't use it very often, but is nice to have just in case.
David
pete81eaglefanasty
« Reply #4 on: October 03, 2006, 05:44:51 PM »
on my eagle model 10 - 15  it is in the battery cabinet were the three battery switches are. just below the switches. on the right side just behind the duel wheels.
      Pete
  Fantasy
WHAT EVER YOU DO, OR TO WHO YOU DO IT TOO, DO IT WITH A SMILE, IT MAKES IT LEGAL THAT WAY.
