February 20, 2018, 09:41:51 PM *
Author Topic: Power steering ?  (Read 772 times)
travelingfools
« on: July 28, 2011, 09:43:17 PM »
Can anyone suggest what type of fluid I should use for my steering ? Also, by tracing the lines, I assume the fluid goes in the coffee can size reservoir with the sight glass on the curb side of the engine.
87 MCI  9, 6V92 NJT
Tks
thomasinnv
Derrick Thomas
« Reply #1 on: July 28, 2011, 10:00:26 PM »
Yes it goes in the coffee can sized apparatus on the curb side mounted just rear of the head. should be a fill spout mounted to the curb side of the intake air horn on top of the blower. You can use atf if it's the stock steering setup.
1998 MCI 102-DL3
Series 60 11.1/Alison B500
« Reply #2 on: July 30, 2011, 08:46:53 AM »
If it is Sheppard, 15W-40 engine oil.  All others normal ATF. Look and see if your fluid is red (indicating ATF) or clear (could be hydraulic oil or engine oil).  Good Luck, TomC
travelingfools
« Reply #3 on: July 30, 2011, 09:12:27 AM »
Thanks all... it was atf.
