May 20, 2013, 09:52:06 PM *
Author Topic: Need advice before I really get into it  (Read 497 times)
wal1809
« on: August 07, 2011, 12:25:32 PM »
Alright I got one side of the crossover line undone.  I had to take the piece off of the head that clifford talked about with the thermostat in it and that allowed me to get to the one side of the crossover I was able to get to.  The left side is tucked under a piece bolted to the blower with three bolts.  I am assuming that is the fuel pump, gear driven by the blower.  If I can take that off this might give me enough room to get to the left side fitting on the crossover fuel line.
Question is this, is it a matter of 3 bolts to take it off or am I messing with a timing gear behind there?  If it is bolt on and off then it is a go.  What do I need to know before I go poking a stick at the sleeping bear?
www.snakebreaker.com
« Reply #1 on: August 07, 2011, 01:01:20 PM »
No gears there Wayne pull the fuel pump 1 of those bolts is not all that easy to remove lol good time to check the drive yoke on the pump anyway if it is wore in the square replace it they don't cost that much 10 bucks or less check the pump for wetness they are design to leak to the outside through the weep holes may not be your hose leaking
« Last Edit: August 07, 2011, 01:07:27 PM by luvrbus » Logged
wal1809
« Reply #2 on: August 07, 2011, 01:07:04 PM »
Thank you Clifford I would have taken this one to the shop had I known how deep I was going into the engine.  Good experience though as the last time I work on a DD was in 1986 in diesel mech school.  Even that was limited and the engine was on a stand on the shop floor.
« Reply #3 on: August 07, 2011, 01:21:47 PM »
When you install a new line go over the top of the fuel pump easier to do
« Last Edit: August 07, 2011, 01:23:28 PM by luvrbus » Logged
