May 24, 2013, 03:02:14 AM *
Author Topic: PSI  (Read 393 times)
wal1809
PSI
« on: August 08, 2011, 10:54:21 AM »
Does anyone know off of the top of their head what the PSI rating on the fuel system for a DD 6v92?  I think I remember 65 pounds but I have to be sure.
www.snakebreaker.com
« Reply #1 on: August 08, 2011, 11:08:46 AM »
50 to 70 lbs Wayne depending on the orifice in the return line,the relief valve on the pump is set at 85 lbs for the standard pump with 1/4 in gears
wal1809
« Reply #2 on: August 08, 2011, 11:09:49 AM »
Thank you sir!!
azdieselman
« Reply #3 on: August 08, 2011, 11:19:54 AM »
I will add that those numbers are taken at the secondary filter outlet, at full load.
1980 Mod 10
