June 21, 2018, 05:39:59 AM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Ready to get going with the plumbing! Need some help!  (Read 8493 times)
« Reply #30 on: August 20, 2011, 08:03:32 PM »
Why the high dollar shark fitting ? you can remove the crimp ring I have the Zurn removal tool cost 25 bucks and with the pocket crimp tool I can get in place that needs crimping as easy as you can with a shark fitting
pipopak
I am the 99%
« Reply #31 on: August 20, 2011, 08:30:12 PM »
Also make sure you protect the lines from abrasion. Unlike a house that stays still, a bus in movement can rub hoses in ways you will not believe. Be overly cautious when a line goes through a partition or metal piece. There are plastic shields that slip in holes to insulate lines from other materials. Also tie-wrap them as often as possible. Take a look into your engine compartment and note how rubber hoses are secured. You will NEVER be too careful.
Linux, when Windoze just will not measure up.
Pages: 1 2 [3]  All   Go Up
