May 26, 2013, 01:14:54 AM *
Author Topic: Update tax axle issues  (Read 705 times)
wal1809
« on: August 22, 2011, 12:21:39 PM »
Well alright God does look out for fools and small children, BTW I aint small and that leaves only one more choice Grin  Took the bus to a mechanic this morning to check and adjust the brakes.  I asked if they could look at the leak as well.  They found out the fill plug had backed it's way out so they filled it up and tightedned the plug.  No more leaks!!!
One of the tag tires had flat spot on it and the other needed replacing.  So they are replacing the tires and then we will venture on to the next issue of checking the index on tag axles.  So sor far it is just the cost of 2 tires and tighten a plug.  Whew!!
www.snakebreaker.com
« Reply #1 on: August 22, 2011, 12:36:51 PM »
 Wayne back the bogies brakes off or you will be buying 2 more tires lol it won't cause a stopping problem with those backed off,told you she could fix that leak
« Reply #2 on: August 22, 2011, 12:57:32 PM »
 Roll Eyes
wal1809
« Reply #3 on: August 22, 2011, 01:51:09 PM »
I consider myself very lucky so far.   Grin
muldoonman
1991 Prevost 8V92TA
« Reply #4 on: August 22, 2011, 03:30:28 PM »
Wayne, Who are you all using around your area to fix problems?
Glen
wal1809
« Reply #5 on: August 22, 2011, 03:47:48 PM »
Glen
Hello Muldoon.  I am using Slivas automotive in Wallis, Texas which is south of Sealy.  I trust they know what they are doing but they have no idea what is going on so far as indexing the tag axle.  If I find a good shop for busses I will let you know.
There used to be a shop on I-10 west of Schulenberg, Texas.  They work on big trucks only.  The next time I get close I am going to stop and talk to them.
muldoonman
1991 Prevost 8V92TA
« Reply #6 on: August 22, 2011, 03:51:58 PM »
Yeah, I've seen the shop if it's on I 10. On the north side?
wal1809
« Reply #7 on: August 22, 2011, 04:17:41 PM »
Yes Sir that is it.  I remember when I was a kid it was a little shop.  Over the years the shop has grown quite a bit.
muldoonman
1991 Prevost 8V92TA
« Reply #8 on: August 22, 2011, 04:41:39 PM »
I think they advertize Detroit D.
glen
wal1809
« Reply #9 on: August 22, 2011, 05:06:28 PM »
I am not sure when I will be headed west on I-10 next but I will make it a point to introduce myself and find out what they have going on over there.  That would be pretty convenient for me if they can work on them, and I reckon you too as well.
