viking1
Viking
Offline
« on: September 01, 2011, 04:24:33 PM » |
Has anyone ever considered using sheetrock in a bus? I'm guessing it would be a bad idea, but thought I would ask. I have a section in the main living area of the coach behind the couch. An area of approx 4*12 feet and it would start at the floor and go up to the window. Any thoughts???
Price is what you pay. Value is what you get
« Reply #1 on: September 01, 2011, 04:35:02 PM » |
not a fan: have seen it crack in a home from settling and sometimes for no good reason, can't imagine what would happen in a moving bus with vast temperature swings. Might be the new better way. Bob
Bob@Judy 98 XLE prevost with 3 slides --Home done---last one! SW INdiana
wal1809
« Reply #2 on: September 01, 2011, 04:54:08 PM » |
Sheetrock would not be good at all. Even walking from the front of the bus to the back of the bus will move the bus. Your tape lines will crack before you can make it to the fuel pumps.
« Reply #3 on: September 01, 2011, 04:58:48 PM » |
I'm sure it has been considered and even done, but it is obviously a bad idea. Now stucco for the exterior would be original.
« Reply #4 on: September 01, 2011, 05:01:36 PM » |
There is a high end 5th wheel manufacture in La Grande Or named Arctic Fox that uses sheet rock they use some special jointing compound probably regular stuff with some type additives to keep it flexible. I have seen 5 or 6 years old Arctic's with no cracks we have friends with a 36 footer those are $$$$ 5th wheels, it is not screwed into the studs I have no idea how they attach it my friend says clips I know the top and bottom have a channel
« Last Edit: September 01, 2011, 05:07:44 PM by luvrbus »
neverlearn
« Reply #5 on: September 01, 2011, 06:03:53 PM » |
Good question. I have been contemplating the use of drywall in the bus because of my paranoia of fire and the fire-resistant properties of drywall. I am interested to see where this thread goes.
Anything worth doing, is worth OVERdoing. 1984 MC-9: Went from Passenger service to my driveway where it stores the components for its upcoming transformation. 6V92 HT740 Palmyra, VA
« Reply #6 on: September 01, 2011, 07:08:48 PM » |
I live a mile down a dirt road that goes washboard for part of the time. We have also traveled miles at a time on roads that are worse. I don't think that drywall would hold up to the thumping. I also would merely not want to add that to my list of worries. Further, some materials could tolerate a minor leak for a bit, drywall is not as likely to.
Brassman
« Reply #7 on: September 01, 2011, 07:16:22 PM » |
I'd use green board. Could the judicious use of glue and screws make it a no cracker (along with latex mud)?
« Reply #8 on: September 01, 2011, 07:54:37 PM » |
I ask Buddy what sheet rock was used in their trailer he said it is not the home owners type it is called Tuf/Base or Ultra/Base made by USG 3/8 thick and is water proof like green board it is made with some composite material to stop the warping and cracking. He went on to tell me Country Coach used the vinyl covered in some of their units he is going on 7 years now with 53,000 miles hasn't cracked yet and they just changed the inside colors they love it said cuts down on outside noise may be a option for the old standard wood, carpet or wallpaper walls. It looks to me like the top and bottom rail which are stainless steel would be a little costly
« Reply #9 on: September 01, 2011, 08:06:26 PM » |
I definitely think outside box! so keep us posted on results and products used. Bob
Ed Brenner
« Reply #10 on: September 01, 2011, 08:18:58 PM » |
Weight might be a consideration ? Of course if you are using granite countertops and ceramic tile floors, then it gives you a good excuse to update to a modern 4 stroke ! Thanks ED
Ed Brenner 77 Eagle 05 Murrells inlet, SC " While We're At It " A Busnut's most costly Phrase !!
viking1
Viking
Offline
« Reply #11 on: September 01, 2011, 08:34:41 PM » |
good idea. Ill tell the wife if she wants granite and tile I get a 4 stroke. Only fair, Right? LOL
« Reply #12 on: September 01, 2011, 09:27:22 PM » |
3/4" furniture grade plywood with reinforcements. Gives the narrowest walls possible and still looks good. Very strong too. Good Luck, TomC
JWallin
« Reply #13 on: September 02, 2011, 03:28:59 AM » |
We used it in out 4107 and it works great. We have made two cross country trips while full timing over two and a half years and no problems at all. Very easy to install and maintain. No cracking from the flexing bus as predicted by the naysayers (who never tried it) and we are very pleased with the results. We did use green board in the shower, with tile. It's interesting to read what a non-starter it is, given our personal experience.
JWallin
« Reply #14 on: September 02, 2011, 03:32:21 AM » |
Another point worth mention, we spent two winters in the Rockies... the temperature range we encountered during this time ranger from a low of -16 degrees (once for two weeks) to 98 degrees. In case anyone is wondering....yes, I'd do it again.
