June 19, 2013, 12:13:56 PM *
Author Topic: Winter in a 4106  (Read 2125 times)
Tevo
« Reply #15 on: September 14, 2011, 01:35:14 PM »
Thanks! I did the window film in the trailer and it worked ok, but I'm really hoping to source some dual panes before then. I found that even running a big dehumidifier in the trailer, I was still getting ice on the window film.
Man, just thinking of that gets me hating winter again!
That is NOT necessary.  You to mount the film differently.  If the film is stretched across any metal surface that is part of the window frame you will get heavy condensation on the parts in contact.  I put that tine half circle self adhesive insulation foam tape on all the metal edges that will contact the film.  Stuck the film to areas that were wood paneling and wouldn't conduct heat.  My walls used to have water running down them till I did that.  All is dry now.  That film stuff is the best stuff ever.  I even put it on my windshield interior and drove with it for 6 months....crystal clear.  I cleaned it many times with Windex and a soft cotton cloth and it was still unscratched and clear when I took it off.  Magic stuff.
I never capped my waste tank vents.  The AC can be insulated from the inside by just dropping the shroud/deflector and stuffing a piece of foam up in there.
Hmm, makes sense. If I don't get the windows done in time I'll give that a try. Thanks for the tip!
1962 GM PD-4106
« Reply #16 on: September 14, 2011, 01:38:48 PM »
I looked up the record low temps - june, july and august - 29 - 32 degrees!  chilly!  Average night time lows in the 50's all summer.  Colder than Cape Breton!
1980 MCI MC-5C converted
Vintage race cars -
1978 Lola T440 Formula Ford
1972 NTM MK-4 B/SR
Tevo
« Reply #17 on: September 14, 2011, 01:48:26 PM »
Oh, record lows...I thought you meant they've had freezing temps this year. Generally the weather in the summer here has been amazing.Almost everyone here RV wise are fulltimers from Phoenix who spend the summers here then head back down. But the park management did say we'll have about 24 people staying over this winter. It should be pretty similar to how SD was, only with more entertainment options.  Smiley
1962 GM PD-4106
« Reply #18 on: September 14, 2011, 02:15:59 PM »
Those heat strips in the AC proved near usless for me.  At best, they are what they are advertised to be....A CHILL BREAKER.  They are not part of your heating system.  They are intended to be turned on when you get home and the RV is "cold soaked".  With the furnace on full the Strips are turned on to stir the air and add a "little" heat.  For the amps they draw you would think they would do more.
You need a propane furnace.  They don't add moisture t the air.  The Catalytic Converters dump tons of water into the air.  If you don't have a propane furnace you NEED one so you might as well get it installed.  If you can't get the ducting done then just let it dump into the interior.
You must have a small fan running 24/7.  it sits on the floor and blows straight up.  This de-stratifies the air and makes the place comfy.  No cold feet.  Just a small desk fan is sufficient in some remote corner.  Throw away every year rather than clean unless you are cheap like me.
HTH,
Tevo
« Reply #19 on: September 14, 2011, 02:23:15 PM »
That hasn't been my experience. Propane furnaces in the two travel trailers I had dumped tons of moisture, which is why I took to using a dehumidifier (though it could have just been the cheap design of the systems). The neighbor beside me in SD actually quit running his furnace and used a cat heater instead and had better results, which is partially why I chose the cat over a furnace. For that matter, I'd say of the 15 people in the park up in SD I was at, probably 10 had went to cat heaters rather than use their furnaces, though most just liked them better since they were more efficient and less because of the moisture. Either way, the dehumidifier seems to do the trick for me.
« Last Edit: September 14, 2011, 02:37:09 PM by Tevo » Logged
1962 GM PD-4106
« Reply #20 on: September 14, 2011, 02:40:21 PM »
A cat is in a different "world" than a furnace in regard to efficiency.  Hands down.
Here is the bottom line:  When combustion happens you get three things....Heat....carbon dioxide/monoxide....AND water.  Many don't understand that the air coming out of a furnace exhaust is "wet" but just go and put your hand in the air stream.   Sure it is hot but it should feel "wet" as well.  Regardless of what you might feel it is certainly water vapor laden.  This isn't a point tha can be argued....it is a fact of physics and chemistry.  There are tables that list the weight of the carbon you add to the exhaust for every pound/gallon of propane you combust.  There is also a table that lists the gallons or pounds of water you create by combusting a pound or gallon of propane.  Gasoline and D...the same applies.  So the long and short of it is: with a furnace you dump that water vapor outside but with a cat you dump it inside.  Only way for a furnace to add to the interior humidity is to have the exhaust leak into the interior but water will shortly fall way down on your list of concerns if that happens.  I have been there.  Whats that smell?HuhHuh??  Oh, crap!  sort of thing.
cats are great but all that use them also leave a window open to dump the water vapor and the CO2.  Have a CO detector on at all times.  make sure the cat has an auto shutoff if it sees a build-up of co2 or depleted O.
Tevo
« Reply #21 on: September 14, 2011, 02:52:01 PM »
I'm certainly not an expert in furnaces and am not sure how the furnace introduced moisture in. It wasn't leaking since we never smelled anything and neither our propane leak monitor nor our CO detector never went off. But the moisture difference was very clear. We have a weather station that gives us indoor/outdoor humidity levels and we could sit and watch it climb when the furnace had been on. Any idea what could have caused it? I don't have the first clue.
1962 GM PD-4106
« Reply #22 on: September 14, 2011, 03:43:03 PM »
It won't freeze or snow in Flagstaff until at least Oct!! 7000'+ elevation does that!!
The only thing I ever had freeze in my 4104 was the toilet valve and spray heads for the toilet and galley sink. Those things really are easy to crack. All I used was two electric heaters, one in the water tank comp and one in the bathroom. However, winters in Ark are nothing like Flagstaff.
« Reply #23 on: September 14, 2011, 07:34:48 PM »
I'll second the vote that heat strips in AC units are useless in sub-freezing winter conditions.
I've always wondered about the heat loss out through the unit while it blows air up into that cavity pretty much canceling any positive effect. Stuff it full of insulation and call it done?
If using those amps, I prefer to use them down on the floor using cube heaters.
The moderating effect of open windows on humidity cannot be discounted.
Just breathing, we put some serious moisture into the small space that is a coach.
Closed up with the furnace, or opened up with a cat, the two are hard to compare.
My encouragement would be a number of smaller heat sources that ganged together will carry you through the coldest, and then may be selected individually for efficiency and redundancy.
Consider the loss of external power and how you will continue boondocking.
Rare to meet someone who complained they had too much heat in the winter, but met lots of folks who wished they had more!
Tevo
« Reply #24 on: September 14, 2011, 07:41:28 PM »
To clarify, I have no intention of relying on heat strips. I'll be using a catalytic heater (Olympian Wave 8    ) supplemented with a small electric.
1962 GM PD-4106
desi arnaz
« Reply #25 on: September 15, 2011, 03:19:11 AM »
What a bunch of pussies.... I go out in my shorts and bare feet at 32degrees.
My  vote is a couple of electric heaters up top and at 32 outside there really shouldn't be a problem with tanks freezing.as long as you are in a rv park the power should be free but if not it is a he'll of slot cheaper and safer than propane. I would also use reflectex  on the windows at night.
thomas f  Bethlehem n.h
Tevo
« Reply #26 on: September 15, 2011, 04:01:33 AM »
Unfortunately, it gets much, much colder than 32 here.  Sad Average low through winter is in the teens and it often dips into single digits and the negatives.
1962 GM PD-4106
JWallin
« Reply #27 on: September 15, 2011, 07:13:48 AM »
We spent the last two winters in Colorado in our  4107. With our hydro heat system and a small oil filled space heater we stayed 77 degrees inside with temps as low as -15, once going for a week and a half without getting above 0. Our equipment bay is heated and the temp monitor down below never went below 40 degrees as far as I know. Once temps go below freezing the energy curve begins to take on some exponential characteristics even with good insulation. You will be able to easily discover all of the places you still need to insulate. Hint- The drivers area, dash, steps, and entry can be challenging.
desi arnaz
« Reply #28 on: September 15, 2011, 07:35:23 AM »
 i still think electric heaters would be the cheapest. put one down in the water bay also. still cheaper than propane at $3.30 a gallon.
chuckd
« Reply #29 on: September 15, 2011, 09:32:09 AM »
I have spent the past few winters skiing near Bozeman Montana.  Last year I used my Liberty Conversion Prevost.  It is pretty well insulated with foam, and all bays are heated and insulated.  The best change I made was to have my sister make me some shades with warm windows fabric.  It did an excellent job of keeping out the cold.  (to be accurate, not losing heat).  You won't make it with a 8,000 btu cat heater not enough btus, and moisture will be a concern, keep a vent open.  I put insulation on all but the bathroom vent.  I use foil bubble insulation on the front windows.  Heater outlets become cold outlets, letting in the cold from the cold antifreeze, need to cover them after traveling.  Air condition evaporator outlets are very cold as well.  Your door will be an excellent place to lose heat.  I had a 40k diesel fueled espar air heater, and built in electric heaters to keep nice and toasty down to -13F and lots and lots of wind.
Good luck and remember to snuggle.
Chuckd
