May 22, 2013, 08:31:55 AM *
Author Topic: Wire chaneel used?  (Read 656 times)
uemjg
« on: September 19, 2011, 07:59:14 PM »
I'm looking for suggestions on what wire channel people have used on the interior of their bus. I'm interested in running 12 volt d.c. wire for overhead lights and was looking for a product to hide it...suggestions?
scanzel
« Reply #1 on: September 20, 2011, 03:44:27 AM »
I think we need more info on your question. Exposed or concealed ?
Steve Canzellarini
Berlin, CT
1989 Prevost XL
uemjg
« Reply #2 on: September 20, 2011, 05:33:29 AM »
This is for overhead lighting and the dc wiring would run on the surface.
MEverard
« Reply #3 on: September 20, 2011, 06:02:10 AM »
There are numerous forms of wiremold and trim that would work for a surface mount. Is there a reason that you can't conceal it? The method you use will should be decided by the finishes you are working with and what will work best with them.
Good Luck,
Mike
Mike Everard
1960 GMC PD4104-4520
Antioch, CA
happycamperbrat
« Reply #4 on: September 20, 2011, 10:55:05 AM »
I like the idea of doing a small hinged box at floor level for water lines and at the corner where the ceiling meets the wall for electrical lines. The two hinged boxes would run the full length of the coach and then all wiring and water lines would be easy to get to.
« Reply #5 on: September 20, 2011, 10:59:45 AM »
Most wiring is hardly ever needed to be accessed once its run but it would be smart to run some rope or string along with existing wires in case you want to pull others thru later on.
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
uemjg
« Reply #6 on: September 20, 2011, 11:17:43 AM »
Happy do you have pictures of this hinged box?
happycamperbrat
« Reply #7 on: September 21, 2011, 09:27:44 AM »
Haha!!! Only in my mind  Grin You wanna come inside and look around?? Scary place in there for sure!!!
