February 19, 2018, 02:23:18 AM *
Author Topic: Used Aluminum wheels  (Read 1279 times)
Bus Busted
My other truck is a Bus!
1984 Eagle 10, 1986 MCI 102A3
« on: October 14, 2011, 08:24:31 PM »
With two events that I know of this weekend (one in North Indiana and one in South TN) if anyone sees a set of 6 Aluminum Rims for sale could you let me know. I have a 1986 MCI 102A3 with stock tires. I have the 6v92 turbo engine W/ 4 speed auto tranny. I think that some go with larger or smaller tires when going to Aluminum Rims and not sure how that will work with this engine setup. Let me know, Thanks Jon
1985 Eagle waiting repair of burn damage
1984 Eagle Model 10, just started conversion
1986 MCI 102A3, seated when bought, conversion on hold until Eagle is done
demodriver
« Reply #1 on: October 14, 2011, 08:46:51 PM »
You need to make sure that you get the correct style of wheels for your bus. I think there is three different styles.  Do a search on here and you should find all kinds of info.
Eric
RoyJ
« Reply #2 on: October 14, 2011, 10:39:38 PM »
The size would depend on if your current gearing is under, over, or just right. On a 40' coach, you can probably get away with any size in terms of load rating, so your only worry is diameter.
Chances are, your current wheels are "Budd" style. AKA stud centric. Make sure you get the wheels with the large, chamfered holes!
When I changed my rears this summer, I upsized from 20.00R20 to 22.4R24.5. This gained me 3% in gearing, which was much needed as I have a 4.11 rearend. If I went with 22.5R22.5 I would've lost 3% Sad I avoided 315/80 due to cost and availability.
Utahclaimjumper
« Reply #3 on: October 15, 2011, 04:55:27 AM »
You may also have to install longer studs to fit the new wheels,, check before buying.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #4 on: October 15, 2011, 07:49:49 AM »
MCI could have stud, or hub piloted wheels or 5 of each type on each like the prison bus models use
