April 25, 2018, 05:19:41 PM *
Author Topic: ground info needed.  (Read 2368 times)
uemjg
jerry
« on: October 17, 2011, 04:52:45 PM »
I have a MCI-8 and wondered if the aluminum floor in the cargo bays was a good place to attach a ground wire from the inverter/charger?
« Reply #1 on: October 17, 2011, 05:50:54 PM »
The best way is to run the ground directly to the batteries.
uemjg
jerry
« Reply #2 on: October 17, 2011, 05:57:34 PM »
not sure i understand...
« Reply #3 on: October 17, 2011, 06:10:47 PM »
Yes, it's a fine place for a ground.  But the better way to go is to wire your inverter/charger directly to the batteries with cable for both the positive and negative main cables.  Use the chassis ground for very low current uses like lights, a radio, etc.
edroelle
1998 Royale Prevost
« Reply #4 on: October 18, 2011, 03:48:34 AM »
I would tend to find another location.   Being low, it is susceptible to moisture and corrosion, especially with different metals.
Ed Roelle
Flint, MI
« Reply #5 on: October 18, 2011, 08:51:29 AM »
It really depends on what the ground is for.  If it is the negative connection to the batteries then you don't want to connect to the frame or any part of the bus.  some inverters like mine have a separate chassis ground.  I connected my chassis ground directly to the steel structure of the bus.
uemjg
jerry
« Reply #6 on: October 18, 2011, 02:01:39 PM »
The info I'm requesting is for the ground on the inverter and NOT the negative side...I am currently using the cargo aluminum floor for the ground.
« Reply #7 on: October 18, 2011, 02:08:57 PM »
Not sure I understand.  It would be best for both the positive and the negative connections of an inverter to go directly to the battery.  I believe the instructions on mine even said that.  However, if you are talking merely about a ground for the casing of the inverter, the floor may be okay.
« Reply #8 on: October 18, 2011, 03:13:45 PM »
Are we sure the question isn't about the ground/earth on the inverter's output - ie. the AC....
thomasinnv
Derrick Thomas
« Reply #9 on: October 18, 2011, 09:55:33 PM »
he's talking about the chassis ground lug on the exterior of the inverter. The floor of the bay is fine.
1998 MCI 102-DL3
Series 60 11.1/Alison B500
« Reply #10 on: October 19, 2011, 04:09:36 PM »
The "case" ground is relative to the AC voltage of the inverter.
Donald PH
