April 26, 2018, 04:23:57 AM *
Author Topic: Cutting Holes Through Bottom of Cargo Bay  (Read 6321 times)
Jerry32
« Reply #15 on: November 05, 2011, 06:46:40 AM »
I don't use the slinky hose as they always go bad. I bought the sewer solution long ago and it has a 1" hose and has lasted for many years.
1988 MCI 102A3 8V92TA 740
Scott & Heather
MCI-9 & MCI-102
« Reply #16 on: November 06, 2011, 03:41:39 PM »
Ditto on the sewer solution. I love it...I'll never go back to a slinky hose. That being said, I've cut a notch out of the BAY DOOR itself along the bottom edge. Just another way...and eliminates the underneath clearance issue.
Scott & Heather
Dave5Cs
« Reply #17 on: November 06, 2011, 06:50:32 PM »
5\8" hose through the bottom, also won't ever  go back to 3" flex hose. Mine is hooked to a disposerator 3\4 HSP. Works like a dream
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
« Reply #18 on: November 07, 2011, 05:19:17 PM »
Do you guys really use the Sewer Solution for regular dumping of tanks at a dump station?  Doesn't it take way too long?
I own a Sewer Solution for dumping at home, but it generally takes 15 to 20 minutes to empty my tank.
Scott & Heather
MCI-9 & MCI-102
« Reply #19 on: November 07, 2011, 07:24:23 PM »
Not at a dumping station..slinky is best for that, but when I'm at a full hookup site (like now) I use the sewer solution. I have a 100 gallon black/grey combo tank and it doesn't take nearly 20 minutes to drain...rather about 5-7 minutes...I just go outside, turn on the valves, open the dump valve and let er fly. Then I go about working on some outside project until I hear the sewer solution burp signaling it's done. Easy, clean, and effective.
Scott & Heather
« Reply #20 on: November 09, 2011, 04:03:45 PM »
Scott,
You're a very brave man. Considering the very high pressure the macerator pump puts on the smaller hose there is a very real possibility it could burst - I don't have the nerve to walk away from mine for even a minute!!
Scott & Heather
MCI-9 & MCI-102
« Reply #21 on: November 09, 2011, 04:18:39 PM »
Scott,
 Shocked Yuck! The Sewer Solution I use isn't actually a macerator..rather it merely uses water-jet power to liquify the..um...tank contents as they drain past the water jet. Not a whole lot of pressure actually. And, the hose is thick stuff...super thick walled. Hose is stainless hose clamped at both ends and after the 10 foot hose, it's all 1 inch pvc from there to the drain. Again, not a ton of pressure, but it's effective. My current run is 40 feet and slightly uphill.  Undecided Go figure. Who designs these lots?
Scott & Heather
« Reply #22 on: February 15, 2012, 04:20:13 PM »
Never heard of the injection pump system like you have? Sounds like a good system. However, considering all the money I have in my portable macerator I have to stick to it.
I agree, that probably doesn't have much pressure.
Scott & Heather
MCI-9 & MCI-102
« Reply #23 on: February 19, 2012, 05:36:08 AM »
Yeah, basically "drain assistance" more than anything. But enough water jet propulsion to keep things moving down the line...again, even on a slight uphill.
Scott & Heather
