May 25, 2013, 10:08:02 AM *
Author Topic: 8v92 exhaust  (Read 594 times)
1960eagle
« on: November 08, 2011, 07:32:22 AM »
i am look for a set of manifolds and pipes to turbo.any ideas?  8v92 .thanks
« Reply #1 on: November 08, 2011, 07:37:25 AM »
What kind of turbo setup do you have? Is it the same that is used on trucks with the turbo on the top of the engine?  Detroit made dozens of different setups and exhaust manifolds for turbos.  Are you running one turbo, two turbo's?  Give us some more info so we can help you.  Good Luck, TomC
« Reply #2 on: November 08, 2011, 07:46:25 AM »
Front mounted or top mounted turbo I have both sets of manifolds but shy on the pipes for the front mounted I have plenty for the top mount even with the expansion tube,nothing for the rear or side mounted turbos,guessing from your screen name it going in a Eagle unless you raised the floor it will be a front mount.The old 8v71 manifolds will work by flipping the manifolds and reducing at the exhaust flange at the turbo or manifold
« Last Edit: November 08, 2011, 07:59:16 AM by luvrbus » Logged
1960eagle
« Reply #3 on: November 08, 2011, 08:57:23 AM »
it is for 01 model eagle.front mount single turbo. sorry for the lack of detail in first post.
akroyaleagle
« Reply #4 on: November 08, 2011, 03:08:48 PM »
Does any of this help?
8928605 low profile blower housing (could be 8922167)
5104464 low mount engine bell housing from a Ford Truck with a 6v92 or 8v92
9402015 crankbolts (12)
23045507 adapter hub, flexplate to crank
5143106 Y manifold
8922502 front turbo brackets
E8927027 Garret Turbo A/R .81
5101174 double cooler w/wp pipe
A BIGGER RADIATOR!!!!!!
Be sure to plug the 2 holes (5/8")between the
blower and governor housing!
Drill the lube orifice for the front blower bearing if you go with the optional turbo (front of engine) mount
Joe Laird
'78 Eagle
Huron, South Dakota
