May 23, 2018, 10:08:51 AM *
Author Topic: jake brake question  (Read 1401 times)
uemjg
jerry
« on: November 08, 2011, 07:31:11 PM »
Where would I find taller valve covers for a jake brake setup?
thomasinnv
Derrick Thomas
« Reply #1 on: November 08, 2011, 08:04:30 PM »
someone on board here may have some or know someone who has some. Check fleabay also. You do NOT want to buy those new.
1998 MCI 102-DL3
Series 60 11.1/Alison B500
« Reply #2 on: November 08, 2011, 10:28:47 PM »
You can also use spacers with your valve covers-but then you have a second spot for oil leaks.  Taller aluminum (not the stamped steel) is the way to go.  Whether it be a 8V-71 or 8V-92 they use the same valve cover.  Good Luck, TomC
scanzel
« Reply #3 on: November 09, 2011, 03:25:38 AM »
Check some of your local truck scrap yards. They may have some 8v71 or 92's laying around that may have them on them.
Steve Canzellarini
Berlin, CT
1989 Prevost XL
« Reply #4 on: November 09, 2011, 04:22:49 AM »
For what engine
uemjg
jerry
« Reply #5 on: November 09, 2011, 04:59:45 AM »
8v71
« Reply #6 on: November 09, 2011, 05:10:14 AM »
Ok now where are the breather locations and do you have a oil fill on the covers and where is it located lots of different variations for the covers I am asking not to be smart @$# but I have a couple of sets
