May 22, 2018, 08:35:56 PM *
Author Topic: just wondering the cost  (Read 4138 times)
uemjg
jerry
« Reply #15 on: December 05, 2011, 07:08:45 AM »
@ Busted Knuckle: The Highways on the eastside are 610 loop east and the I-10 (East Freeway)...apparently there's a few Heavy Equipment repair shops on the eastside of town.  If you recall the name then I should be able to find it.
@ Ralph: It's factory steering...a side note: When make turns on long wide freeways the steering is tight, but straight away its still a little loose.  I recently drained the steering fluid and refilled and bled it with the recommended oil instead of fluid.  But I also feel the fronted loose when going over bumps at low speeds.
