February 21, 2018, 03:20:05 PM *
Author Topic: new photos of WVO  (Read 1543 times)
glenn
Glenn & Sharon
mci 9
« on: October 21, 2006, 04:34:53 AM »
http://pg.photos.yahoo.com/ph/packmanjamie/album?.dir=/bc76re2&.src=ph&.
« Reply #1 on: October 21, 2006, 09:26:49 AM »
Excellent looking system.  Keep us informed on how it works!  I assume it is an L10?  With the Cummins PTS mechanical system the WVO should work well.  Have you considered also making a blending system?  Be able to vary the percentage of WVO you'd run on rather than just on/off?  Just a suggestion in case you get a batch of not so good oil, but runs well with a little Diesel mixed in.  Good Luck, TomC
Paso One
« Reply #2 on: October 21, 2006, 03:04:10 PM »
You Have done a lot of nice work there. The plate heat exchanger is that mounted to the tank containing the WVO???
1996 MCI 102 D3
