May 24, 2018, 10:56:15 AM *
Author Topic: windshield washers  (Read 1457 times)
mikke60
Out with old, in with the not as old
« on: December 26, 2011, 05:28:50 PM »
This summer I got my pneumatic windshield washers all cleaned up and working on my 5a.. Removed it and put in the garage to replace that last O ring. Tonight I went out to do a few things and found the washer unit on its side with the bottom plastic tank busted. Any body have any clue as to if this could be replaced ,or is a total replacement the best solution.
thanks.Mike
« Reply #1 on: December 26, 2011, 05:36:49 PM »
Does that one swing out with door like on the MCI-8? reason I ask might have one in surplus parts. If so will ck tomorrow.   Bob
Boomer
« Reply #2 on: December 26, 2011, 05:46:20 PM »
For used, try Caylor Supply.  For new try MCI.  Pretty standard across the older MCI line.  I would convert to electric myself, you can pick up the parts out of a junk yard, or one source for new is Hayden.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438
'65 Crown Atomic, NO MORE
Vancouver, WA USA
mikke60
« Reply #3 on: December 27, 2011, 12:54:48 PM »
Thanks, Bob
I will send a pic
pabusnut
« Reply #4 on: December 27, 2011, 07:57:23 PM »
I converted my 4905 to electric after I did a post-mortem on the old pneumatic pump.  It was a bunch of dried up rubber, broken springs and rusty goopy water!  After google searching for what seemed to be days, I discovered that there aren't new ones being made.
The hardest part of converting to electric was installing the 24to12VDC converter I had bought a while back.  I figure the effort wasn't wasted as I will need other 12 VDC gadgets while underway, including my new GPS speedometer.
Steve Toomey
pabusnut
Steve Toomey
PAbusnut
« Reply #5 on: December 28, 2011, 12:52:37 PM »
My windshield washer is pneumatic, but not a pneumatic pump.  Air pressure is used to move fluid from the tank out to the windshield.  There is an electric solenoid valve that controls the operation.  Very simple.
mikke60
« Reply #6 on: December 28, 2011, 05:10:25 PM »
this is a pic of my washer set up. it is the glass bowl at the bottom that is missing. it is about 2.5 inches dia. and about 4 inches tall.
thanks
« Reply #7 on: December 28, 2011, 05:41:36 PM »
total differant than what I have. sorry.  Haven't seen one like that.  Bob
