May 20, 2013, 12:10:32 PM *
Pages: 1 2 [3] 4   Go Down
Author Topic: Bus stuck again - more comic relief from Lyons Moose bus - tow question  (Read 3231 times)
viento1
« Reply #30 on: February 07, 2012, 10:29:32 AM »
Getting to the proper jack points... impossible!  use the lugs to fasten a home made bracket to the wheels. Use bottle jack to lift the wheel, fill in the big hole. Repeat on other side and tags... works like a charm.
Or
Buy  a kinetic rope. I have had the bus belly resting on soft sand and the tide was rising. Some crazy fool used a stretchy rope and pulled me out with a dodge pickup... amazing process. I now keep a kinetic rope on the bus at all times. Wish I were there to play in the mud with you.
Ok, it's time to go on another road trip.
www.randalclark.com
MC5
desi arnaz
« Reply #31 on: February 07, 2012, 01:56:01 PM »
  this may sound stupid but what if you filled  the airbags all the way up then blocked the frame  then let all the air out? would that help/work?
thomas f  Bethlehem n.h
Jriddle
« Reply #32 on: February 07, 2012, 02:30:41 PM »
I have seen this was quite amazed wasn't a bus though.
John Riddle
Wells NV
1984 MC9
« Reply #33 on: February 07, 2012, 03:58:25 PM »
In short, no.
You'd get the body up but the problem is that the tires are sitting in holes.  If he's down so low that the belly is creating suction to the ground then he's really in trouble.  In that case raising the body is part of the solution but he still needs to get the tires out of their holes.
1981 Prevost 8-92, 10 spd
blank
« Reply #34 on: February 07, 2012, 10:22:48 PM »
In short, no.
  I explained this earlier. You can either jack up the weight of the entire Bus, or only the weight of the axle. Raising the Bus and blocking it will allow you to jack the axle quite easily after blowing the air. One the axle comes up, fill the hole, and raise the Bus with air. A low profile floor jack should be able to be slid under the axle enough to lift it.
jjrbus
MCI5C/N Ft Myers FL
« Reply #35 on: February 08, 2012, 12:03:54 AM »
Usually once you are stuck there is no place to put a floor jack. Even if you can get it under the bus, without blocking the jack will only sink. Unless of course you are stuck on concrete Grin I do like the lugnut jig idea sounds good?   JIm 0311
wg4t50
« Reply #36 on: February 08, 2012, 03:44:37 AM »
Seems getting the bus unstuck is not the issue, seems the issue is to get as much mileage out of such a stupid subject.
If getting the bus unstuck and under way, one would have a suitable wrecker, simply extract it.  Where am I wrong ?  Shocked
Dave Metzger
Had MCI-7 20+Years, Few Engines & Transmissions
8V-71, 12V-71 & 8V-92, RR RTO-910
Too old to crawl around/under, so Bought a Foretravel ISM500
Still love the ole Bus, clock ran out of time.
« Reply #37 on: February 08, 2012, 05:41:18 AM »
We carry a "snatch strap" rated at 40,000 lbs. Have not used it yet an hope we never do, but it is nice to have Just In Case.  Jack
chev49
« Reply #38 on: February 08, 2012, 07:28:08 AM »
Some of us would rather get out in the mud and jack the thing up... Grin
« Reply #39 on: February 08, 2012, 10:08:39 AM »
Go back and view the original pictures.
Only through complete misapplication of efforts will that coach require anything more than some shovel work at the tires.
Getting to be a long winter, and we're bored and cabin feverish?
« Reply #40 on: February 08, 2012, 12:00:10 PM »
Just hook a chain to the reindeer.
« Reply #41 on: February 08, 2012, 12:05:45 PM »
I can't believe it's still stuck - it's been weeks!  Anyway, get a big plastic bag, connect it to the bus air system, pump it up and the bag will gently lift (or rip) the bus up out of the holes.  They sell them, maybe you can rent one.  Used in all sorts of industries for rigging things, and in accident response.  They used one to lift a train off someone in Toronto once.
http://www.hovair.com/products/matjacks/air-lifting-bag-index.html
A 5 foot diameter bag stuck under the bus would lift with a little over 2800 lbs of force per PSI of air inflation.  In theory.   Grin
edit:  Ha!  I was right!  found this...   http://www.windsorfire.com/divisions-apparatus-equipment-extrication-tools-pneumatic-lifting-bags    apparently they have some made for buses that use only 7.5 psi, and other that use high pressure including from vehicle air brake systems...  so call your local fire department and get them to run a training exercise!
« Last Edit: February 08, 2012, 12:12:08 PM by bevans6 » Logged
1980 MCI MC-5C converted
Vintage race cars -
1978 Lola T440 Formula Ford
1972 NTM MK-4 B/SR
« Reply #42 on: February 08, 2012, 02:03:20 PM »
There are inflatable jacks which work of the vehicle's exhaust. Not perhaps much use lifting a bus though.
I claim no expertise at all in dealing with this kind of situation but my instinct is that what is really required here is a pull or push, not a lift. The bus is stuck on an icy surface, not up to it's sills in mud or sand. And is the push or pull required even that great? The bus is operational so it's not like you're trying to pull a dead weight. You can get hand-operated Tirfor winches which will lift 5 tons, and that's before using snatch blocks to increase the purchase. Wouldn't this be more than enough to help the tyres get a grip?
« Reply #43 on: February 08, 2012, 02:20:04 PM »
 Shocked Got a few chuckles out of this one. Doing what I did as a profession and being a hard headed do it myself type. I understand!! Will admit We have winch trucks sitting around and would not be a problem.  This is one best to spend a few bucks on if you don't have the T-Shirt.(been there done that).  Probably less than $75. Plus no one gets hurt.  I have seen your daugther!  Seams to me she could charm enough team members to push or lift the bus out Shocked.   Tuff to be a dad of a teenage daugther.  Bob
« Reply #44 on: February 08, 2012, 07:05:23 PM »
Those recovery bags do indeed run on only a couple pounds of air.
At the roll over recovery demonstrations I've been at, they bring volunteers out from the audience, whip off the hoses and tell them to cap it with their hands. Pretty good comedy when you add in some fake anxiety!
Well Phil, what's going on???
Pages: 1 2 [3] 4   Go Up
