January 22, 2018, 08:15:49 AM *
Author Topic: AC units?  (Read 6671 times)
muddog16
« Reply #15 on: January 31, 2012, 07:45:42 PM »
I'm a little confused here!  Are these even rated for RV appilcations?
Pat
1982 Prevost LeMirage
8V92TA/HT754
« Reply #16 on: February 01, 2012, 04:59:33 AM »
Simple answer no: the RV rated industry doesn't build anything close to this efficient. I used them. very satisfied. My total load for ac is less than 20 amps start up and running plus I have heat also down into the single didgets (tested by me). That 20 amps is about or maybe a little more than one roof top. Plus they are so much quieter.  You must pay attention to condensate drain and use common sense and make sure the unit is set level or tilted a little toward the low end.  I prefer the 410 refrigerant system and the inverter system ones with a ser factor around 15 or over. I have not found a rating on a roof top but knowledgeable ones have guessed around  9ser.  The lowest mini-split is 11ser.  I have 3 in my 45 ft coach total cost $1450 on 100 degree day 70 inside 2 will maintain and kick off. Heat is equally impressive in the teens once warmed up one 9000 unit pulling 6.5 amps will maintain 70F.  I have 1  12000 btu unit and 2 each 9000 btu units.   Test results are my test. I am not a salesman or have any intrest other than bus building hobby.    Bob
blank
« Reply #17 on: February 01, 2012, 06:19:46 AM »
Here is the tag on the box.
  No multilingual tag? I'm shocked, lol
muddog16
« Reply #18 on: February 01, 2012, 06:33:13 AM »
If I was using common sense I wouldn't be using a unit not rated for motor homes or RV's,  what it comes down to is.........its cheap!!!! (don't confuse cheap with building with less cost) but saves you a couple of bucks......This is the extension cord argument but with ac's........I have to shake my head and laugh......  only in America!    Roll Eyes
Pat
8V92TA/HT754
« Reply #19 on: February 01, 2012, 06:51:01 AM »
I am interested to see how they hold up over time the power from generators are not really all that clean and RV parks you never know now Bob in the US may have the advantage over Steve in Mexico down there the roads are so bad it shakes the sheets off the bed for some reason to me 400 lbs psi and vibration don't mix.
I am keeping a open mind with the wait and see Bob will tell of any problems I think lol
Good to see you posting Pat I read your email everyday I am still unable to respond to it I have a hard time finding the words my friend
zimtok
« Reply #20 on: February 01, 2012, 07:46:32 AM »
With a Mini-Split where did you put the "outside" unit?
I would think that if you put it in a bay then you would not be able to use it as you drive unless you allow for some sort of ventilation.
1960 PD4104-4971 - Memphis TN
http://www.eddielsmith.com
« Reply #21 on: February 01, 2012, 08:54:10 AM »
I'm not first here. They have been in use for several years in Rv Mci 8 Tin tent for at least 5 yrs.  Just more vocal.  I put condenser in front spare tire compartment  and another in old condensor compartment.. DuWayne said anchoring the lines is very important to longivity of instalation. And use soft copper. Also consulted with Nick Badame on board with instalation.  The RV industry is in a Slump now and has no insentive to change anything.  No need to follow like sheep.  I haven't used roof tops in last three conversions. Don't like noise  and poor performance .    Do it your way! I will do it mt way.   Bob
« Reply #22 on: February 01, 2012, 09:24:36 AM »
RLA= rotor locked amps (running)
FLA= full load amps
LRA= load rated amps
You've got a couple of those backwards, Clifford.
RLA is "Rated Load Amps"
LRA is "Locked Rotor Amps"
The RLA is, for all intents and purposes, the running draw of the appliance under maximum rated conditions.  For an air conditioner, that would be at the highest rated outside temperature with the maximum temperature delta.  That said, the RLA is not really intended to be used for performance measurement, rather, it is the number you use to specify fuse, breaker, contactor, and wiring size for the appliance.
The LRA is the maximum current that will be drawn when the rotor is locked, which is essentially the start-up current.  Fuses and breakers must be rated to accept this amount of current for short periods of time.  In the case of fuses, they are designed for a slow blow, wherein it takes a while for the fusible element to heat up to the melting temperature.  For breakers, you want to use a type designated "HACR" which stands for Hating, Air Conditioning, and Refrigeration and will have the required overcurrent time delay built in.
HTH,
« Reply #23 on: February 01, 2012, 09:33:47 AM »
Consider the source Sean LOL
Oonrahnjay
« Reply #24 on: February 01, 2012, 01:24:45 PM »
  With a Mini-Split where did you put the "outside" unit?   I would think that if you put it in a bay then you would not be able to use it as you drive unless you allow for some sort of ventilation.
     You wouldn't be able to use it parked, either!
« Reply #25 on: February 01, 2012, 02:46:49 PM »
Copper is not good for any installation subject to  vibration because it work hardens.
It is forbidden in aircraft for that reason. You don't see any copper lines in autos either.
« Reply #26 on: February 01, 2012, 03:13:29 PM »
I pointed out anchor securly! Was one of Mci 8 tin tents points. He is a hvac professional. Really don't feel Like big argument here. I will take my chances and repair if necessary. You can use flex hoses if necessary. By the way I took    copper  lines out of my Prevosts and have done same on Mci also.  Just my way. Not sugesting anyone try experiment. Easy to call camping world. Tried and true method of the ages for 30 years. Noise very little improvements. (some but few).  The roof tops will serve your purpose! Insulate well! Buy a properly sized Gen set. Have a large battery bank for inverter use(for very short time).  The 45XLE I'm presently building had 4 each roof tops and a very large gen set before I  started it. It now has 3 Mini-split units and a 7.5 kw snall gen set. which is more equal to campground plug in power availability where we camp quiet often. I've ratteled quiet enough as it is water under bridge for me.  Good luck! Do it you way.   Bob
« Reply #27 on: February 01, 2012, 03:21:32 PM »
Not to be a smart alec, but MCI apparently didn't by into that theory. We have a bunch of long copper runs, on our coach. Both air lines, and AC. Both continue to work great. Some of the newer coaches have copper too. Apparently they didn't buy into that theory either.
Bob, thanks for sharing your insights. Sounds to me like it will work just fine. Not using copper on buses? Naw, that ain't the case. Use away, my friend.
uemjg
jerry
« Reply #28 on: February 01, 2012, 06:52:54 PM »
I agree with bob on the mini-splits and the use of copper.  I will be using a 2 zone mini split on my conversion as my budget allows.
If anyone has any leads as to where i could get a dual zone, inverter type mini split as a complete kit, let me know.
thx!
AndyG
« Reply #29 on: February 01, 2012, 07:22:16 PM »
Gus, you are partially correct about copper.   It is more likely to crack due to vibration that some other materials but is can be made to work.  There has been plenty of hard & soft copper tubing used by OEMs to carry both refrigerant and hot water in our coaches.  There was a pretty big pile of it, from a Prevost, behind Dad's shop at one time.  Proper installation is the key to using copper in a mobile application.  Reduce or eliminate movement where possible.  Use wide sweeping turns and loops where a small amount of movement may be needed.  I have a 1935 tractor that has copper fuel lines.  You bus will not shake like a non-balanced 4cyl engine running at 1200RPM while bouncing through plow furrows.  They solved the problem by putting a 2.5" Dia loop in the fuel line to account for vibration and movement.
