June 20, 2018, 12:28:11 PM *
Author Topic: MCI 8 air problem  (Read 7311 times)
thomasinnv
Derrick Thomas
« Reply #15 on: February 17, 2012, 10:38:17 PM »
the only access to those front tanks is by crawling under the bus. be careful, busnuts have been squashed to death.
1998 MCI 102-DL3
Series 60 11.1/Alison B500
« Reply #16 on: February 18, 2012, 12:22:38 AM »
You don't need a shovel to find the rear electric junction box, just open the driver's side engine access door, the one on the side, not the rear. The junction box is mounted right there on the wall, to your left, inside the fender for the tag wheel.
If the temps are below freezing, you might want to just wait?
There are too many variables for trouble shooting for throwing frozen moisture in any random place into the mix.
I really, really hate wasting time working on something that doesn't need working on, due to bad diagnosis.
Some call me lazy, some call me smart...
« Reply #17 on: February 18, 2012, 04:00:43 AM »
There are four tanks on your bus.  The dry tank is behind the rear wall of the rear luggage bay on the driver's side, and the drain valve is through a small door at the foot of the wall just inside the luggage bay door.  The two tanks in the front axle bay are the emergency tank and the wet tank.  The wet tank is on the drivers side and the emergency tank is on the passenger side.  The pressure protection valve and the E-filter are mounted on the emergency tank.  There are normally pull type drain valves that you can attach a chain or cable to, or hook with a long stick with a bent end.  The last tank is the accessory tank, it's up front under the driver's seat in the compartment there.
buylow8
« Reply #18 on: February 18, 2012, 01:11:17 PM »
Thomas or anyone else
Do you have the drawings for the airbags?
kurt
« Reply #19 on: February 18, 2012, 01:51:33 PM »
What drawings did you get from Thomas?
All that stuff you've mentioned in the thread is on the stock drawings.
Pretty rare for that E filter to get clogged.
Also, pressure protection valves tend to fail by letting the air through early, as the spring ages or breaks, not block it up completely.
As Brian suggests, is there air present in all the tanks, and drain them, and see what the recovery might be?
I'm thinking blockage, as opposed to failure.
buylow8
« Reply #20 on: February 18, 2012, 02:08:24 PM »
Thomas gave me an air brake system drawing. i hope it warms up a bit more so my problem goes away on its own
kurt
thomasinnv
Derrick Thomas
« Reply #21 on: February 18, 2012, 09:55:33 PM »
I just emailed you the suspension air schematics. I didn't even notice they weren't part of the schematics i sent you already.
BW, the pressure protection valve absolutely can fail in the described manner, and not just by opening too low. I had the same exact problem as the op describes a few months ago due to a sticky ppv. My air would go over 100 before the ppv opened. can be common in colder climates.
1998 MCI 102-DL3
« Reply #22 on: February 19, 2012, 11:19:33 AM »
Crack open the lines leading to the ppv and give it a shot of your favorite air tool oil.
Be prepared to do a little re-adjust once it is freed up, but after it has been cycled a few times. let it settle in to its new found freedom.
My use of words may have led us astray?
Sticking is a blockage, which can be remedied,
failure requires the replacement of the component due to it being unable to perform as intended in a permanent manner.
Many apologies!
buylow8
« Reply #23 on: February 22, 2012, 06:14:24 PM »
Thomas
thanks for the air suspention drawings.
I ran the bus again when the temp went into the high 50s and its still not working. I had a truck mechanic stop by and he hooked up his air compressor to the emerg fill air valve and was able to release the emerg brakes. i am going to drive it to his shop a mile down the road and have him fix it. i will post what the fix was
kurt
« Reply #24 on: February 22, 2012, 06:17:48 PM »
good news! you'd like for your mechanic to explain to you what he has done, what diagnosis he did, what he found right, and what he found wrong, and what he did to fix it.
Not so much for us, but for your own growing knowledge of how the beast functions.
If you learn as you go along, he gets more business, if you don't learn anything....
Scott & Heather
MCI-9 & MCI-102
« Reply #25 on: February 22, 2012, 06:44:19 PM »
Kurt Just a side note on your engine stop lever. You said you have to manually kill it by pulling that lever. Is it stiff when you pull it? If so, it's merely not returning via spring to it's off position. You merely need to unseize the lever from it's likely seized washers down near its base. Fixed my problem. Much safer than reaching in there every time.
Scott & Heather
buylow8
« Reply #26 on: February 22, 2012, 06:55:07 PM »
scott
the lever is not easy or hard to turn. it looks like there is an actuator that should push the lever but it looks like it or the lever was moved out of the way. i guess the guy before me had a problem with it and moved it. i never fixed it because it is about # 10,000 on my things to do list
kurt
thomasinnv
Derrick Thomas
« Reply #27 on: February 22, 2012, 07:27:25 PM »
the spring is not what activates/operates the engine stop lever, the air cylinder operates it. If it was moved to the side by the PO then chances are that once the air is up in the system you will find the air cylinder to be energized. you most likely have a faulty air valve, engine stop switch, or faulty wiring between the two. For those that don't know, MCI uses a remote air valve mounted on the rear bulkhead, which activates the air shutoff cylinder on the governor.
1998 MCI 102-DL3
Scott & Heather
MCI-9 & MCI-102
« Reply #28 on: February 23, 2012, 04:56:06 PM »
scott
kurt
Oh ok...different problem than mine was.
Scott & Heather
