April 21, 2018, 07:00:13 AM *
Author Topic: need help with dirty glass...  (Read 1244 times)
uemjg
jerry
« on: February 21, 2012, 11:06:25 AM »
My MCI8 has windows that look like they have large water spots or white haze on the outside.
Are these cleanable?  with what?  Can they be micro-polished?
« Reply #1 on: February 21, 2012, 11:23:04 AM »
It would have laminated glass in all windows, even the single pane ones.  Are you sure you aren't seeing delamination?  Other than that, alcohol based cleaning solutions I would think.  If you think it's a stain of some sort, maybe acetone.
uemjg
jerry
« Reply #2 on: February 21, 2012, 11:32:39 AM »
I'll try to post pics and maybe it will be more evident.
junkman42
« Reply #3 on: February 21, 2012, 12:34:04 PM »
I had stains on a rear window of a car and was told by a detail shop it was from water from My yard sprinklers!  I thought They were nuts but found out that it was iron stains from well water.  I buffed the glass with the same polish I used on plastic aircraft windows.  Not a easy task!  John L
Rick 74 MC-8
« Reply #4 on: February 21, 2012, 03:12:52 PM »
The best glass cleaner I have found is Turtle wax crome cleaner about 3d bucks use as directed If it streaks wait longer to remove  Grin
                             Rick 74 MC-8
« Reply #5 on: February 21, 2012, 03:38:41 PM »
Sounds like double pane glass and the stains are actually on the inside. More than likely you're going to have to have a window shop split the planes above and clean the insides and reseal the panes
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
