May 20, 2018, 10:54:51 AM *
Author Topic: What type of disconect switch  (Read 1050 times)
goutoe
« on: March 13, 2012, 07:58:34 AM »
I would like to install a disconnect on my start up batteries 12 volt system on my AM general 6v92 what type or brand would You guys recommend? I installed a blade type on the coach batteries which works great but I don't think that would be heavy enough to handle starting amps. Thanks John.
John & Linda 1977 AM General 6V92 turbo Detroit 3 Speed allison, 40 ft.
« Reply #1 on: March 13, 2012, 09:54:53 AM »
Same subject here:
http://www.busconversions.com/bbs/index.php?topic=23099.msg253950#new
It is hard to beat the Cat switch listed.
« Reply #2 on: March 14, 2012, 03:21:48 PM »
I use the cheap green knob cutoffs from WM. They are not the most rugged but are the cheapest and most available.
I probably have 20 of them in use now including the buses and have had only one fail in 20 years.
I use one on each battery so that cuts down on the starting current load.
goutoe
« Reply #3 on: March 15, 2012, 07:39:29 AM »
Thanks for the help guys I located a switch off of a caterpillar loader I just need to build a bracket and I should be in business. Thanks, John.
