April 19, 2018, 08:38:09 AM *
Author Topic: What is this paneling called?  (Read 4326 times)
Uglydog56
« on: March 14, 2012, 10:08:42 PM »
On this picture I stole from ebay, what is the name etc. of the paneling behind the counter?  That's what I want to do the walls of my kitchen/dining room in.  I'm sorry it's hard to see.
Rick A. Cone
Silverdale, WA
66 Crowny Crown "The Ark"
natepelton
« Reply #1 on: March 14, 2012, 10:34:07 PM »
wainscotting right?
Nate Pelton
1983 Prevost LeMirage
North Creek, NY
Seayfam
« Reply #2 on: March 14, 2012, 10:41:30 PM »
Typically it would be used for wainscoting, but it's called beadboard paneling.
Gary Seay (location Alaska)
1969 MCI MC-6 unit# 20006
8V92 turbo 740 auto
« Reply #3 on: March 15, 2012, 05:10:58 AM »
What we used give us the same look, but we used individual boards that are about 3  9/16" wide, 5/16 thick and come in 8' lengths, instead of the 4x8 sheets of fir paneling. The boards are available at Home Depot and Lowes in pine or cedar.  Jack
Ericbsc
73 05
« Reply #4 on: March 15, 2012, 07:06:38 AM »
That is oak bead board. If it is a solid pc. it will be 4' x 8' x 1/4" sheets. It can also be purchased in strips but they are thicker. Both should be available at any cabinet or home supply.
« Reply #5 on: March 15, 2012, 07:11:38 AM »
Doesn't wainscoting just mean wall covering ? guess I could look it up lol
Uglydog56
« Reply #6 on: March 15, 2012, 08:40:28 AM »
Thanks guys!  I'm going to get the 4x8 sheets and make the lines horizontal, then go all the way up and over to the cabinets.
Next question:  My bus came with 1/4" plywood cladding over the insulation, nothing over that (the interior wasn't finished).  Would you put the beadboard over the plywood, or in place of it?
Rick A. Cone
Silverdale, WA
Cary and Don
« Reply #7 on: March 15, 2012, 08:56:56 AM »
Wainscoting is a wall treatment, paneling or something else, below a chair rail.
Don and Cary
1973 05 Eagle
GM 4107
Neoplan An 340
1973 05 Eagle
Neoplan AN340
pabusnut
« Reply #8 on: March 15, 2012, 10:50:54 AM »
I was going to use the 4 x 8 sheets, but at my big box store, they are now only pre-finished at $40ea. Calculating that I would waste about 1/3 of each sheet, I decided not to go that route. Some of them are not wood either, but a thin verneer over pressed hardboard.  I am not fond of that stuff as it doesn't mix very well with water!  Knowing that leaks are probable sometime--I avoid anything that will be damaged by first contact with water.
I am going the route Jack did with the individual boards, which I can stain, and hopefully waste fewer of!
Steve Toomey
pabusnut
Steve Toomey
PAbusnut
« Reply #9 on: March 15, 2012, 11:22:41 AM »
My local stores have them in 36" X 48" panels specifically for wainscoting.  I call that look "tongue and groove" because in the old days you made it by cutting tongues and grooves on boards, usually pine, and it was used for the backs of cupboards and all sorts of things.
chev49
« Reply #10 on: March 15, 2012, 12:33:04 PM »
have seen beadboard both at lowes and home depot
mikke60
Out with old, in with the not as old
« Reply #11 on: March 15, 2012, 05:19:26 PM »
I would go over the 1/4" for rigidity.
Fred Mc
« Reply #12 on: March 15, 2012, 10:02:06 PM »
Its easy to make you own beadboard using plywood. In my house kitchen reno I made my own by cutting dados(grooves) in plywood and gluing dowels into the grooves.
Regards
Fred
« Reply #13 on: March 16, 2012, 06:39:41 AM »
use to call     car sideing      from the railroad days.   telling my age  Grin
Paso One
« Reply #14 on: March 16, 2012, 08:25:18 AM »
I have a short wall section I was thinking on using up some left over tongue and groove 3/4 inch flooring.
You would get the same look. Smiley
1996 MCI 102 D3
