February 19, 2018, 08:14:19 AM *
Author Topic: 8-71 odd noise  (Read 1708 times)
tmathis
Born to Boogie
« on: March 25, 2012, 10:51:05 AM »
getting an odd "chuffing" noise from the drivers side cylinder bank. almost like an exhaust leak (but it's not). also a bit of excess grey smoke from that side. I had the rack run about 1000 miles back, this started about 500 miles ago. it's not getting any worse. I may be imagining it but it feels a little down on power too. Any ideas?
Tony Mathis
1971 Eagle
8v71
Utahclaimjumper
« Reply #1 on: March 25, 2012, 04:49:15 PM »
You may get that if valves are a little on the tight side. It would be easy to check with a feeler guage.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #2 on: March 25, 2012, 05:29:29 PM »
Better have it checked someone may have used the bridge adjustment to set the valve clearance I hope not but it does happen
« Last Edit: March 25, 2012, 06:13:04 PM by luvrbus » Logged
tmathis
Born to Boogie
« Reply #3 on: March 25, 2012, 06:10:19 PM »
easy to check, hard to get to..
Oh well, nothing better to do next weekend.
Tony Mathis
1971 Eagle
8v71
Geoff
« Reply #4 on: March 25, 2012, 06:30:05 PM »
Find a good 2-stroke DD mechanic (not a plug-in-technician) to figure it out.  If you paid someone to do it the first time you should not try to fix it yourself.
Geoff
'82 RTS AZ
tmathis
Born to Boogie
« Reply #5 on: April 01, 2012, 08:27:55 PM »
Valves were fine. While I had it opened up I checked the injectors (hold down he plunger with a big screwdriver method). Sure enough, bad injector. Ordering one tomorrow. Any recommendations for sellers on a DD 60c injector (reman).
Tony Mathis
1971 Eagle
8v71
