January 23, 2018, 06:18:11 AM *
Author Topic: Wiring a thermostat  (Read 2532 times)
opus
« on: March 28, 2012, 08:39:55 AM »
You know, just one of your normal bi-metalic ones you might have in your home.  Its got 2 leads on it.  I want to wire it into a fan to come on at a certain temp.  I assume I cant run 5A through it so I would have to use a relay to run it?
chev49
« Reply #1 on: March 28, 2012, 08:47:24 AM »
i haven't tried to do that... but i would think one of those car relays for security systems, etc would work just fine. they can be bought on eBay cheap for 10 at a time..
Thanks for the idea...will try that also, as i have lots of the relays, and some thermostats...
baker4106
« Reply #2 on: March 28, 2012, 01:39:30 PM »
You are right, don't try to run 5A.   I purchased a relay at a locale auto parts store to run mine and it works fine.
mikke60
Out with old, in with the not as old
« Reply #3 on: March 28, 2012, 01:47:54 PM »
you can also buy a thermostat intended for use with electric baseboard.Can handle plenty of amps.mike
Jriddle
« Reply #4 on: March 28, 2012, 02:17:15 PM »
This is what I did. I run 12v for the fan through them seems to work great for me.
John Riddle
Wells NV
1984 MC9
opus
« Reply #5 on: March 28, 2012, 09:22:41 PM »
Can someone point me to a particular item or make, model, etc?
Sorry, should have looked first.  This should suffice?
http://www.ebay.com/itm/Honeywell-T410A1013-Electric-Baseboard-Heat-Thermostat-/360437283184?pt=LH_DefaultDomain_0&hash=item53ebbc7970#ht_2787wt_819
Better yet?
http://www.ebay.com/itm/Suburban-RV-Furnace-Thermostat-12V-part-161154-/140656834374#ht_500wt_819
« Last Edit: March 28, 2012, 09:29:00 PM by opus » Logged
Jriddle
« Reply #6 on: March 29, 2012, 06:24:12 AM »
I would go with the first model. The second may not support the amp draw that you may need.
John Riddle
Wells NV
1984 MC9
mikelcan
Considering a conversion
« Reply #7 on: March 29, 2012, 08:15:15 AM »
 I would think that a heating thermostat would work opposite of what you desire.  They are designed to turn something on when the temperature drops below a set point.  For a fan you would want an AC or attic fan thermostat that will turn the fan on when the temperature is above a set point.  I would think that this would work:
http://www.ebay.com/itm/Attic-Fan-Thermostat-120-240VAC-Model-1A22-7-New-/120743373884?pt=LH_DefaultDomain_0&hash=item1c1cddac3c#ht_793wt_1112
Mike
Jriddle
« Reply #8 on: March 29, 2012, 08:21:06 AM »
Mike
True
Depending on the use of thermostat I assumed he wanted to turn on a fan in a heat exchange.
Good Point
John Riddle
Wells NV
1984 MC9
opus
« Reply #9 on: March 29, 2012, 08:50:08 AM »
Sorry, I want the fans on the heat exchanger to turn on at 67 or whatever.  No AC involved.  I should have clarified.
opus
« Reply #10 on: March 29, 2012, 02:51:47 PM »
Will the Honeywell work with just 12V?  I see it is rated for 120/240.  I dont suppose the voltage would really matter, would it?
Jriddle
« Reply #11 on: March 29, 2012, 05:31:17 PM »
Will the Honeywell work with just 12V?  I see it is rated for 120/240.  I don't suppose the voltage would really matter, would it?
Yep pretty much what I have.
John Riddle
Wells NV
1984 MC9
« Reply #12 on: March 29, 2012, 05:51:52 PM »
A simple bi-metal thermostat really shouldn't care about voltage.  Some fancier thermostats might need power from the furnace, but many of them work on batteries these days.
I had bought some dead simple bi-metal thermostats, but they turned out to be junk.  The quality was terrible and the setting wouldn't stay were it was was set.  I bought some $15 digital thermostats instead that have batteries.  I have yet to try them.
opus
« Reply #13 on: March 29, 2012, 05:56:18 PM »
Ok, I will grab a couple of those Honeywell stats.  This way I can run the power right to it and not have to deal with relays.
