May 23, 2018, 05:41:56 PM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Series 60 & Allison 4060 tranny  (Read 8786 times)
benneu
« Reply #30 on: April 09, 2012, 09:00:15 PM »
Thank you Brian.  I send you an email.
Ben
Don Fairchild
« Reply #31 on: April 10, 2012, 01:05:29 PM »
my 8V92 is DDECIII with an HD 4060 and runs 6Th gear. It will down shift one or more gears depending on the conditions when I apply the Jake's. I have had too hit the throttle and or turn off the Jake's a few times because it will overspeed the engine if I am to aggressive on the brakes when decending a hill. My Chevy will do the same thing, it will down shift more then gear if I stay on the brakes to long when in trailer towing mode.
Don
« Reply #32 on: April 11, 2012, 06:05:21 AM »
You can program the transmission to down shift to 2nd or 4th on Jake Brake.  Personally-I like all that turned off so I can control the down shifting since many times you just want a bit of Jake.  Besides-how hard is it to down shift an automatic transmission-either pushing a button or sliding a shifter?  Good Luck, TomC
Ericbsc
73 05
« Reply #33 on: April 11, 2012, 07:10:04 PM »
I had my tcm programmed to my engine by TKT Transmission. He is an Allison guru I have been told. On the WTEC IV all communication is done using a twisted pair and protocol J1939. I do know that this is available only wtec IV and above. Whit the wtec III down separate wires have to be run between engine, and transmission for some functions. No other wires connect between my engine. and transmission. It down shifts one gear when jake is applied. I would like to have more control over that but on the other hand it slows much quicker with the shift.
Pages: 1 2 [3]  All   Go Up
