April 19, 2018, 05:06:09 AM *
Author Topic: How to install a primer pump  (Read 7162 times)
dougyes
« on: April 16, 2012, 02:29:31 PM »
I've replaced a bunch of fuel lines and I still get air in the line, especially after the coach sits for a few days. After priming the filter it fires right up. I was thinking of installing a little fuel pump at the tank to add some boost to get it started. Can I put one inline in the fuel line? Advance Auto sells a bunch of inexpensive little fuel pumps. Any suggestions on which pump to get?
« Reply #1 on: April 16, 2012, 02:34:06 PM »
I would figure out why the coach is losing prime after sitting just a few days and then worry about a pump once it is fixed.  A pump would just be a band aid and not a real fix.  My bus can sit all winter and it will fire right up after all that time.
« Reply #2 on: April 16, 2012, 02:37:04 PM »
Checked your profile: what kind of bus do you have? Bob
dougyes
« Reply #3 on: April 16, 2012, 02:39:10 PM »
102 DL3 with a series 60
« Reply #4 on: April 16, 2012, 03:09:49 PM »
I agree with the bandaide-my '77 AMGeneral transit bus can sit for weeks and still fires up like I ran it yesterday.
I watched Don Fairchild prime up my 8V-71 after he replaced the head to head cross fuel line.  He first disconnected one hose at a time-filled the hose with Diesel then reattached it. Then filled the fuel filters with fuel and tried to fire the engine.  He did the whole thing 4 times, then it started and kept on running.  While Don has used a primer pump on the secondary filter-which is AFTER the fuel pump-he will not use any kind of primer pump before the fuel pump.  Why-he says that the seals on the low pressure transfer pump can easily be blown out by a primer pump.  If you do put a primer pump in, only after the fuel pump-not at the tank.  Good Luck, TomC
papatony
« Reply #5 on: April 16, 2012, 04:09:29 PM »
Doug   some where on the line from the tank to the first filter there is a back flow valve that keeps the fuel from draining back into the tank. start looking back toward the tank it should be close to filterer.      Tony
« Reply #6 on: April 16, 2012, 04:27:24 PM »
I just finished an engine swap. One post I read in the archives suggested what Tom C said. I just finished bought my pump at Oreilys. Installed before the Secondary filter and it worked fine. My system was pretty dry. Clifford also suggested the same location.
Sent from my DROIDX using Tapatalk 2
« Reply #7 on: April 17, 2012, 05:21:27 AM »
Here is the type of pump I used.  I used the 24 volt one.  I just put it in line in the main fuel line to the primary filter, on my 8V71 I don't think there is anything that will be hurt by 10 - 14 psi for 10 seconds...   I just run it for a few seconds, you can hear when it reaches pressure and that means everything is full.  If I leave it on, the fuel pressure switch stops the engine from turning over.  I suspect that your main line check valve needs servicing.
Oonrahnjay
« Reply #8 on: April 17, 2012, 06:22:49 AM »
  (snip)   I used the 24 volt one.  I just put it in line in the main fuel line to the primary filter, on my 8V71 (snip)
    Yeah, but a Series 60 is an electronic engine and they're often touchy about fuel pressure (the fuel pressure is read by a sensor and it's factored in by the computer for Start of Injection timing, Injection Quantity, etc.)  For an ordinary mechanical engine, I think a primer pump is a good idea; for an electronic engine, I'd definitely find the problem and fix it.
« Reply #9 on: April 17, 2012, 07:16:40 AM »
The new stuff all comes with a priming pump from the factory.
What are they doing?
« Reply #10 on: April 17, 2012, 08:34:25 AM »
Priming pumps don't hurt the seals Don must have had a bad pump seal to start with, on the older stuff 2 strokes that is a 65 psi + pump I have one in the shop I saved for Don took  me 131 lbs of air pressure to blow the seal and it was a wore out pump
« Reply #11 on: April 17, 2012, 10:38:59 AM »
I can tell you what the fuel pump does not like, and that is to be starved for fuel. I have one with a sheared drive gear shaft (sheared within the pump housing) that I pulled from my old 6-92 in Amarillo bringing the coach home. I was having the same issue LarryH was having (in the other thread) in B-town Ca. cept that I had a collapsed supply line to the primary, which starved it of fuel and lubrication to the drive gear shaft. While stuck in Amarillo waiting for a replacement to come in, I pulled the old one apart and to my amazement, the shaft was separated from the gear and pulled out of the housing. Here's some pix.
    V
« Last Edit: April 17, 2012, 11:28:14 AM by van » Logged
« Reply #12 on: April 17, 2012, 11:30:12 AM »
My Primer is installed inline, before the primary filter. Almost 5 years, and no problemo's Wink
Iceni John
« Reply #13 on: April 17, 2012, 11:35:05 AM »
Whew!   Good to hear that.   I installed a Facet-Purolator Posi-Flo 60100 electronic fuel pump for priming, and it's between the primary filter (in my case, a Racor 900FG) and the engine's fuel pump.   I specifically chose this pump because it's for older carburetor-equipped cars which need lower fuel pressure than newer fuel-injected cars.   I think it produces only a few PSI, which I hope won't be damaging any seals!   I've had to use it only once, and after running it a few minutes the engine started right up with hardly a hiccup.   So far, so good.
Thanks, John
dougyes
« Reply #14 on: April 17, 2012, 01:09:39 PM »
Van, What model primer pump is that in the picture?
Guys, I'll try to find the check vale.
