April 25, 2018, 03:29:34 PM *
Author Topic: can a car sterring wheel be used in a bus ?  (Read 5560 times)
crown
« on: April 24, 2012, 07:09:11 AM »
 ok as stated any reason a car sterring wheel cant be used. my bus is a 57 model and was thinking
 a 57 vintage car wheel would look nice say 59 cadilac ect . other then making a adapter ? .
 any thoughts ? thanks john
john
 57 crown
 costa rica
dukegrad98
« Reply #1 on: April 24, 2012, 07:18:16 AM »
Do you have power steering?  If not, I would think the leverage of the much larger wheel would be important, depending on the manual steering rack.
Cheers, John
chev49
« Reply #2 on: April 24, 2012, 07:30:35 AM »
of course a car steering wheel could be used... with power steering.  Get one of those chrysler product ones that have one side that is flat....adaptor can be easily made.
course, you will then have to get retro gauges, and dash... Grin
crown
« Reply #3 on: April 24, 2012, 08:02:27 AM »
 hi yes full power stering and a retro dash & gauges if fact i used vintage chrome chevy switches for lights
wippers heat ect thanks john
john
 57 crown
 costa rica
Iceni John
« Reply #4 on: April 24, 2012, 08:25:30 AM »
If you have power steering, think what will happen if you blow a hydraulic hose or if the pump ceases to pump.   At that point you'll have to be able to steer by brute force alone, not a problem on the open road, but a challenge on crowded city streets at low speeds.   I had a high-pressure hose blow out a few years ago, and I lost all my power steering  -  I was thankful I had a full-size steering wheel while I was getting the bus off the freeway and into a parking lot for emergency repairs.
« Reply #5 on: April 24, 2012, 08:32:58 AM »
I had a 1967 GMC Superior conversion.  When we put the power steering in, we also put in the whole steering column from a Cadillac.  It worked great, but could have been a problem if the power steering failed.  Also, the bus only weighed in at about 22,000#.  I think my wheel now is 18inch.  VIP has nice steering wheels of various sizes very reasonably priced.
HB of CJ
« Reply #6 on: April 24, 2012, 11:49:53 AM »
Good answers already given and thank you.  If your power steering fails, will you be able to exert enough steering force to the wheel to safely control the Bus Conversion?
FWIW; my old Crown Supercoach 10-wheeler had power assist steering and I safely drove the coach several hundred miles with no power steering belts.  HB of CJ (old coot) Smiley Smiley
« Reply #7 on: April 24, 2012, 12:15:54 PM »
All buses are a problem when the power steering quits it makes no difference what size wheel you have they are a bitch to steer when the problem happens
fraser8
Fraser
1972 Prevost
« Reply #8 on: April 24, 2012, 03:41:38 PM »
My 57 chev had a 18" steering wheel and when I added power steering the wheel was way to big, it was odd to drive as you could make some real quick turns. I changed it to a 15" after market one made in the same design as the original. Buses use a 18' or 20 " so it just might work on your coach. The only thing I would be concerned about is if was strong enough for heavy use.
Fraser Field
Deroche, BC, Canada
Where the milk cows out number the people, but they can't vote
1972 Prevost, Detroit 8-71/740 Allison automatic, Jakes
Hobbies: restoring classic cars, www.oldambulance.com, arranging old car tours: www.coasters2010.com, www.canadiancoasters.ca
Retired Paramedic
Uglydog56
« Reply #9 on: April 24, 2012, 04:37:09 PM »
My vote:
http://www.speedwaymotors.com/15-inch-impala-style-steering-wheel,58574.html
You can get them in 15 and 18 I believe.  Yep, here's one:
http://www.classicchevy.com/chevy-steering-wheel-assembly-impala-style-1955-1957.html
Rick A. Cone
Silverdale, WA
66 Crowny Crown "The Ark"
crown
« Reply #10 on: April 24, 2012, 04:47:19 PM »
 thanks lots of good thoughts my sterring colum came from a monaco motorhome  and it has i think
 a 18'' vip leather wheel  my thoughts where a white or beige color vintage one with the big chrome
horn ring would look very nice . i dont known what size they where in the 40-50 but they look big
maybe 18'' ? or plan b strip the black paint off my wheel and polish the center to a chrome finish
 [i have done that before lots of work but looks nice ] then maybe add a horn ring ? trying to keep
 a retro look . so any new thoughts thanks john
john
 57 crown
 costa rica
crown
« Reply #11 on: April 24, 2012, 04:56:50 PM »
  rick there nice but was leaning to something like this
  first pic is same wheel as mine
  second is a 49 chevy
  thanks john
john
 57 crown
 costa rica
« Reply #12 on: April 24, 2012, 06:32:31 PM »
Actually, you can make quicker turns with a smaller wheel than a large one.
What a larger wheel gives you is more leverage, less effort, but less turning with the same steering wheel rim movement.
I've had to make a few turns without my PS operating (cold weather, low fluid level) which I never could have done with a smaller wheel. Depends on your arm strength too, I'm an old wimp so I can't do much with manual steering!
trucktramp
« Reply #13 on: April 25, 2012, 07:31:07 AM »
Here's what you need http://www.summitracing.com/parts/GRT-741
Dennis Watson
KB8KNP
Scotts, Michigan
1966 MCI MC5A
8V71
Spicer 4 Speed Manual
Uglydog56
« Reply #14 on: April 25, 2012, 09:40:17 AM »
Well, after a morning on ebay, I really like that chevy one the best - it's thick enough to match the size of the bus, but has the dressy full ring.  I did find this one, which also has a full ring, and it's red so it matches other stuff you've already done:
http://www.ebay.com/itm/1952-Cadillac-STEERING-WHEEL-REPAIRED-AND-LEATHER-WRAPPED-HOT-ROD-RAT-ROD-RES-/280825038149?hash=item41627a0545&item=280825038149&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr
Rick A. Cone
Silverdale, WA
