May 24, 2018, 01:26:15 AM *
Author Topic: Voltage regulator question  (Read 2663 times)
« on: May 11, 2012, 09:31:18 AM »
OK had a voltage regulator go bad and bought a new replacement for it.
Well like an idiot I didn't read the terminal labels before installing it an just put each wire back in the position they came off from.
When done I went from over charging to no charging.
So after thinking about it over night I decided to check what was cast into the housing where each wire goes and sure enough I screwed up!
On the old one it's labeled `NEG, FLD, POS and the new one is FLD, BAT, IGN. OK even I can figure out the the field terminal but which one of the others go where?
BTW this is why dad does our eletrical stuff & I do the mechanical. But dad ain't here!
« Reply #1 on: May 11, 2012, 09:43:17 AM »
Well to answer my own question it seems they sold my sister the "wrong" part # regulator yesterday and I'm jumping in the van to go get the correct one now! (4 hr round trip!)
« Reply #2 on: May 11, 2012, 03:14:46 PM »
BK,
Is this a solid state VR replacing an older not T one?
What did it cost?
I'm thinking about replacing my old one in hopes the surging will stop for my DN50 alt.
« Reply #3 on: May 11, 2012, 05:50:07 PM »
BK,
What did it cost?
Gus as far as I know it's same as the old one. (I'd honestly forgotten they make them "solid state" these days.)
But I can tell ya who to call
ACC Rebuilders
853 R. EH Crump Blvd.
Memphis, TN 38126
901-774-5874
http://www.accrebuilders.com/
« Reply #4 on: May 13, 2012, 08:09:51 PM »
BK,
I goofed on that one!
The 4107  original is already solid state, I must have been thinking of that monster mechanical one on the 4104!!
« Reply #5 on: May 13, 2012, 08:46:23 PM »
ACC Rebuilders
Memphis, TN 38126
901-774-5874
You had to drive all the way to Memphis for a regulator?  I guess Nashville isn't that much closer.  I'm spoiled by living in a large metro area I guess.
It probably cost you more for gas for two trips than for the regulator.
pvcces
« Reply #6 on: May 13, 2012, 10:11:59 PM »
The worst part is the innards have been available on eBay for something like $20, IIRC. The main difference in those regulators is that one takes three connections while the other takes four. The one that takes four requires a case ground that is not labeled.
Why they went to the trouble to do it that way, I don't know. Our manual showed the one circuit, but our bus had the other circuit. It was covered in the supplement, so I got a copy of it.
Gus, I doubt that you will get rid of the pulsation in your lights as long as you are using the 50DN alternator. The regulator and alternator are a slow cycling pair. I do recall that George Lowry said that an aftermarket regulator was able to produce a smooth output.
Good luck.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
« Reply #7 on: May 13, 2012, 11:10:33 PM »
Quote from: Busted Knuckle
ACC Rebuilders
Memphis, TN 38126
901-774-5874
Quote from: Belfert
Well Brian we are EXACTLY 1/2 way between the 2!
And the regulators cost about $150 ea.
« Last Edit: May 13, 2012, 11:15:34 PM by Busted Knuckle » Logged
« Reply #8 on: May 14, 2012, 08:30:20 PM »
Tom,
Thanks.
It really isn't all that bad, about 2-3 needle widths, mostly a nuisance.
For some unknown reason it isn't as bad as when I first got the bus?
thomasinnv
Derrick Thomas
« Reply #9 on: May 14, 2012, 09:15:07 PM »
the best kind of problems are the ones that "fix themselves"  Grin Grin
1998 MCI 102-DL3
Series 60 11.1/Alison B500
