February 19, 2018, 06:05:33 PM *
Author Topic: Webasto bearings  (Read 4153 times)
opus
« on: May 23, 2012, 12:03:15 PM »
Does anyone have a generic part number for the bearings in a DBW2010.  I am going to replace mine for kicks and giggles.  I dont want to buy them through Webasto obviously for the price they want.
« Reply #1 on: May 23, 2012, 12:27:09 PM »
60 bucks for the kit is not all that bad to me by the time you drive all over town and ordering bearing that may work or may not you will spend 60 bucks in a hurry
opus
« Reply #2 on: May 23, 2012, 01:00:47 PM »
The funny thing is Webasto suggested getting them elsewhere for about $10.
fraser8
Fraser
1972 Prevost
« Reply #3 on: May 23, 2012, 03:20:49 PM »
You could mic the bearings you have then use the chart to find the replacement.
http://www.motionindustries.com/motion3/jsp/mii/parametricGuide.jsp
Fraser Field
Deroche, BC, Canada
Where the milk cows out number the people, but they can't vote
1972 Prevost, Detroit 8-71/740 Allison automatic, Jakes
Hobbies: restoring classic cars, www.oldambulance.com, arranging old car tours: www.coasters2010.com, www.canadiancoasters.ca
Retired Paramedic
« Reply #4 on: May 23, 2012, 05:39:21 PM »
Motion Industies is your friend...and if you have one nearby, they will measure for you... Smiley
Donald PH
opus
« Reply #5 on: May 23, 2012, 07:44:14 PM »
Will do.  I have nothing within 120 miles of me, not even a McDonalds.
« Reply #6 on: May 23, 2012, 08:16:09 PM »
The bearing are metric if that means much lol me I wouldn't take the chance the Webasto make so much noise to start with you install the wrong bearings they are loud
opus
« Reply #7 on: May 23, 2012, 08:18:21 PM »
They told me to just go to a "local" skate shop and get them.  Everyone must live within population it seems.
pvcces
« Reply #8 on: May 23, 2012, 10:17:08 PM »
I remember seeing someone post that they could use the bearings from an in-line skate board for something in a bus. Is this the something? I've never checked it out.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
« Reply #9 on: May 24, 2012, 11:58:00 AM »
They are identical to skateboard or roller-skate (the regular kind, I don't know about in-line) bearings, 8x22x7 (bore, diameter, thickness, in mm), ABEC-3 or better.  I just pulled my spares out of my kit to verify.  Should cost at most $4-$5 per bearing in ABEC-3.  I would get ones with metal dust covers; many skate bearings have plastic ones.
« Last Edit: May 24, 2012, 12:00:19 PM by Sean » Logged
stevet903
« Reply #10 on: May 24, 2012, 12:49:35 PM »
Sean - is the part number on those a 608-ZZ?
« Reply #11 on: May 24, 2012, 01:11:09 PM »
Last kit I bought from SureMarine had 12 parts per kit cost me 60 bucks probably 100 bucks now lol but I am stickler about genuine factory parts
I just replaced fan clutch on the Envoy NAPA quoted me 256 bucks for a after market, GMC charged me little over 300 I bought the GMC the original factory clutch lasted for 6 years so I figured what the heck for 44 dollars
opus
« Reply #12 on: May 24, 2012, 01:40:58 PM »
Thanks Sean, this should be them: http://www.amazon.com/Bearing-8x22x7-Shielded-Miniature-Bearings/dp/B002BBI7RE
chev49
« Reply #13 on: May 24, 2012, 05:02:34 PM »
probably same as the sealed roller skate bearings in that case.. would be many in garage sales also...
the bearing supply place i use most of the time can cross reference the numbers on the bearing when i call them. even the small ones for little elect motors...
« Reply #14 on: May 24, 2012, 08:34:48 PM »
... the bearing supply place i use most of the time can cross reference the numbers on the bearing when i call them. even the small ones for little elect motors...
No numbers on my spares, other than ABEC-3 (a grade, not a size).  Often the case with small bearings like this.  I measured mine before I posted.
FWIW,
