May 20, 2018, 03:14:48 AM *
Author Topic: Eagle Model 01 front wiring diagram  (Read 3225 times)
sunlovers
« on: June 10, 2012, 02:29:28 PM »
Good afternoon all!
I am in need of the wiring diagram that is inside the front circut box by the drivers seat. As I understand it is attached to the inside of the door.
I do have a complete wiring diagram of the bus but not of the front circut board.
Any help would be greatly appreciated.
Mike
67 Eagle Model 01
8V71 4 speed
#7080
Mike & Kathy Mingus
1967 EAGLE MODEL 01 SE
4 Speed Manuel, 8V71
Ser. # 7080
Bishopville,SC
« Reply #1 on: June 10, 2012, 03:13:38 PM »
I never saw a diagram in the front panel on a 05 or a 01 only numbers on the wires and bars just follow the numbers in your manual yours should be the same as the early 05's, Brownsville built Eagles will be different 1976 and later
« Reply #2 on: June 11, 2012, 10:25:22 PM »
Just a FYI (info) my Eagle has a schematic in the relay box under the toll window and another in the relay box in the rear engine compartment, I thought all the coaches had them...i learn something everytime I log on here
PS mine is 19952 some say 1977, Title says 1978.
Donald PH
« Reply #3 on: June 11, 2012, 10:48:50 PM »
That is a Browsnville built Eagle not a Belgium,Willie needed that his vision got a little blurred at times from the left handed smokes ,none of the Trailways Eagles I seen have it except a few 10's and the all the 15's it was probably a option from Eagle
« Last Edit: June 11, 2012, 10:58:45 PM by luvrbus » Logged
« Reply #4 on: June 12, 2012, 05:41:22 PM »
 i should photograph them and figure a way to get them transffered to a metal plate or decal....maybe i could trade for a GVWR tag...
Donald PH
sunlovers
« Reply #5 on: June 14, 2012, 12:29:55 PM »
eagle19952,
can you get the front circut panel door off and copy the diagram on a full size copier? that way you could then scan that copy into your computer and then e-mail it out to anyone that might need a copy.
Clifford,
In my front circut box the wires do not have numbers but there are several bars that run up and down with numbers on them. would these numbers match the numbers that are on the complete bus wiring diagram?
thanks
Mike
Mike & Kathy Mingus
Ser. # 7080
Bishopville,SC
« Reply #6 on: June 14, 2012, 08:16:08 PM »
the "panel" is more like a shoe box cover...I don't think a copier can "see" that far....let me scratch my noggin...
Donald PH
chev49
« Reply #7 on: June 15, 2012, 07:34:16 AM »
use a good camera with a sd card and post... Grin
« Reply #8 on: June 15, 2012, 01:48:21 PM »
Is this it?
sunlovers
« Reply #9 on: June 15, 2012, 05:51:34 PM »
WOW!!!! Thats it! Where did you find that? That should solve all my problems....LOL
Mike
67 model 01 SE
8V71, 4 speed
#7080
Mike & Kathy Mingus
Ser. # 7080
Bishopville,SC
« Reply #10 on: June 20, 2012, 09:41:41 AM »
here is one from a GSA model 10 ? just to show that some models did have them....mine has the oler style "horn type" relays...vs the bosch type...still figgerin on mine to post... Grin
Donald PH
« Reply #11 on: June 20, 2012, 10:38:51 AM »
That's got to be the cleanest Eagle electrical compartment I've seen in a long time.
« Reply #12 on: June 20, 2012, 10:41:21 AM »
possibly that is because it has not been busnutted... Undecided Grin
Donald PH
