May 26, 2018, 01:23:00 AM *
Author Topic: What methods do you guys use to trace walls/ceilings?  (Read 1217 times)
« on: July 24, 2012, 07:45:07 PM »
The outside walls and the ceilings in my bus are not straight.  What methods do you guys use to trace these outlines onto a sheet of cardboard or something to make a template?  I can't recall how I did it in the past.
« Reply #1 on: July 24, 2012, 08:10:45 PM »
I use a 12 inch metal fab contour gage that I have had for years but I transfer to the wood not cardboard works for me
« Last Edit: July 24, 2012, 08:27:14 PM by luvrbus » Logged
busdesigner
« Reply #2 on: July 24, 2012, 08:18:56 PM »
Go to the Tech Archives scroll down to How to scribe a wall by Thomas Winterhalter that's me got any questions email me  ( busdesigner)
« Reply #3 on: July 24, 2012, 09:09:23 PM »
Working with cardboard first to make a template out of 1/8" plywood.  Good Luck, TomC
« Reply #4 on: July 25, 2012, 01:08:41 PM »
I realized I have a piece of plywood that is already cut perfectly for the wall contour.  I can use that as a pattern so that will help.
Thomas, I looked at your method and it produces nice results, but it seems like a lot of work.  Thank you for your replies.
