May 20, 2013, 08:58:45 PM *
Author Topic: Basement a/c ?  (Read 787 times)
zukmancdr
« Reply #15 on: August 03, 2012, 07:33:09 AM »
I like your setup, Tom. Do you have the returns for both units coming from the same return, and do you have the blowing into the same ducts or separate?
  Chris.
« Reply #16 on: August 03, 2012, 07:43:28 AM »
Chris-both units are separate.  The rear unit feeds the dinette area (which can blow to the front-I anticipate using this unit for night time use) and has a T to feed the bedroom.  They have individual vents that can be shut off.  The 8" return is under the dinette with a 12" square filter vent.  The front feeds just one vent-I wanted that one to blow hard if need be.  The return is built into the end table of the sofa also with a 12" filter vent.
In the basement (which is part of the interior of the box) is two luovered exterior doors that the A/C units are mounted just inside.  The 6" hot exhaust from the condenser will be ducted under the truck. Since the floor of the box is 42" up from the ground, I don't anticipate any problems with heat.  So the condenser air is drawn in from the side and exhausts underneath-very hard to have the two mix.  Good Luck, TomC
zukmancdr
« Reply #17 on: August 03, 2012, 07:55:45 AM »
Thanks Tom for the info.
Chris
