January 18, 2018, 09:53:31 AM *
Author Topic: Toilet Install  (Read 5438 times)
« Reply #15 on: August 07, 2012, 08:07:19 AM »
I won't do the straight down shot because of the proverbial pile of poo which can block off the end of the pipe if not emptied in time. Just a thought.
Dave5Cs Cool Roll Eyes Grin
Dave does have a point. Our tank is 150 gallons and we move quite a bit. There is no fear that that "stacking up." That is certainly something to keep in mind.
chev49
« Reply #16 on: August 07, 2012, 08:35:15 AM »
I have used a straight line from toilet to tank in all my busses since 1990 or so. I use flexible joints in the line in case of movement.  Occasionally have to spray inside it with the wand thingie...
usbusin
« Reply #17 on: August 07, 2012, 09:05:11 AM »
We had a straight drop on our 4104 bus with 16 years and 150,000+ miles.  On our Freightliner conversion we have a straight drop and 12 years and 126,000+ miles, never a problem.
We do have means to "back-flush" the black tank with the grey water.  The procedure is;
(1) dump the black tank,
(2) leave black tank valve open, shut the main discharge valve and then open the grey tank valve to "back-flush" the black tank,
(3) close the grey tank valve and open the main discharge valve to dump the back-flush from the black tank,
(4) close black tank valve and drain grey tank.
A very simple operation once you get used to it and never a problem with sewage in 28 years!
Just the way we do it!
GaryD
Gary D
« Reply #18 on: August 07, 2012, 01:15:33 PM »
Simpler yet is one tank, just dump and go. Flushing is automatic with grey water in the tank.
Fresh water flushing is a waste of time.
« Reply #19 on: August 07, 2012, 02:39:59 PM »
Gus I would agree!
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
