April 25, 2018, 03:27:47 PM *
Author Topic: Entry step non-skid surface??  (Read 1853 times)
Danny
« on: November 07, 2006, 08:52:54 PM »
What is the best way to go on the entry steps for looks and non-skid?
Danny
boogiethecat
« Reply #1 on: November 07, 2006, 08:59:18 PM »
I use aluminum diamond plate....
1962 Crown
San Diego, Ca
H3Jim
« Reply #2 on: November 07, 2006, 11:17:14 PM »
For better or worse, I just put down some very high density, short nap, commercal grade carpet I had left over.  Most of the time I can just sweep it out the nap is so tight.  Very non skid, and so far I like it a lot.  We'll see how it lasts over time.  I was originally planning pn putting some non skid ceramic tile, but this was easy and I already had it, so in it went.
Jim Stewart
« Reply #3 on: November 08, 2006, 04:37:53 AM »
We used a textured surface ceramic tile. We were concerned about diesel fuel that might be tracked in when fueling at truck stops as well as normal water, dirt, etc.  More work to install, but it looks good and is very functional.  Jack
ChuckMC8
« Reply #4 on: November 08, 2006, 09:23:43 AM »
Danny, I removed the rubber insert that comes in MCI.....I went to Lowes and bought a couple of exterior floormats for the home. They are the bristle kind.....I cut these to fit and inserted them in where the rubber ones were removed. I have been really pleased with these...I can reach down and take them out and shake the crud outof them.
HTH Chuck
pete81eaglefanasty
« Reply #5 on: November 08, 2006, 10:06:05 AM »
    I purchased a RV Sure Step it has a rubber mat that peel  and stick,  also has a illumintes light at night. when entering and exiting the coach. it has a motion sensior to activate the light. we have been pleased with it.
                Pete & Jean
                  Fantasy
WHAT EVER YOU DO, OR TO WHO YOU DO IT TOO, DO IT WITH A SMILE, IT MAKES IT LEGAL THAT WAY.
