April 22, 2018, 02:01:58 AM *
Author Topic: What adhesive to use for Soundown composite foam?  (Read 1255 times)
« on: August 18, 2012, 11:31:23 AM »
My generator enclosure had some composite foam adhered to the inside top of the enclosure.  It came loose and partially melted on the exhaust.  I purchased some Soundown composite foam to replace it.  What is the best adhesive to adhere this to the inside top of the enclosure?
jjrbus
MCI5C/N Ft Myers FL
« Reply #1 on: August 18, 2012, 01:50:33 PM »
Mine was glued and  also held in place with large Huh washers??? for lack of a better word.  JIm
« Reply #2 on: August 18, 2012, 02:21:56 PM »
Probably mechanical fasteners.  The fasteners are attached to the metal with glue of some sort.  I suppose I could use those by grinding off the paint to epoxy the fasteners on.
I'm still wondering what type of adhesive to use.  Some spray adhesives would attack the foam.
