April 23, 2018, 10:15:13 PM *
Author Topic: Hey Gm Guys please help me with this one!  (Read 1323 times)
travlinman
« on: August 29, 2012, 03:33:41 PM »
Hey Guys,
I just got my '06 our of storage and all was good except for my drivers side bumperette. While in storage the bolt/rubber bumpers that hold it together decided to come apart. I looked at my shop manual and it says nothing about these little devices. So what are they and where do I get two more? Just for reference it was the smaller of the two that separated. Thanks for any help in getting me pointed in the right direction.
Cheers,
TM
This bus is for sale - https://gm4106.wordpress.com
« Reply #1 on: August 29, 2012, 03:53:36 PM »
By no means a GM guy lol but those are just a stud type mount www.vibrationmounts.com take your pick they have a lot to chose from
« Last Edit: August 29, 2012, 03:56:09 PM by luvrbus » Logged
travlinman
« Reply #2 on: August 29, 2012, 03:57:22 PM »
Well Clifford you may not own a GM, but I'll bet that you know a slight bit more than most about them! Thanks for pointing me in the right direction.
Cheers,
TM
Sam 4106
« Reply #3 on: August 29, 2012, 04:38:37 PM »
When I had that problem on my GM 4106 I drilled 5/16" holes in the bracket, shown in the center picture, on the bumperette and put 5/16" bolts in the holes. I spot welded the bolt heads to the brackets, made spacers the same thickness as the rubber isolator from 1" round aluminum rod, and bolted the bracket to the bumperette. Then I bolted the bumperette to the compartment door. I don't know why the isolators were there anyway.
Or, you could call Luke at US Coach, 888-262-2434. He probably has new isolators in stock if Clifford's source doesn't.
Good luck, Sam
« Reply #4 on: August 29, 2012, 04:39:58 PM »
TM -
When it comes to GMs, the number to call first is always Luke @ 1-888-262-2434.
Probably has them in stock.
Utahclaimjumper
« Reply #5 on: August 29, 2012, 06:24:41 PM »
 Those are called "LORD" mounts and come in all sizes,,available from McMaster Carr and many commercial outlets,, I've been useing them for years in aviation.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
SPICEY MEATBALL
« Reply #6 on: August 29, 2012, 09:45:33 PM »
I get mine at Harley Davidson, used for battery tray and oil tank mounts, 1/4 20 studs
Ex 1989 Model 15 Predator class War Bird owner
