June 19, 2013, 10:25:29 AM *
Pages: 1 2 3 4 5 [6] 7   Go Down
Author Topic: MCI7 8v71 stranded grey smoke increasing with accelleration (injector issue?)  (Read 8676 times)
Geoff
« Reply #75 on: October 09, 2012, 04:09:19 PM »
I don't know where this 350# compression came from, but an "N" piston (non-turbo) needs 500 psi compression, that is on startup, and that is the minimum-- 550# for a new or rebuilt engine.
--Geoff
Geoff
'82 RTS AZ
« Reply #76 on: October 09, 2012, 07:09:30 PM »
Use the starter they will go 350# then at 900 rpm they should be 500 ,I have friend with N/A 8v71 in a Eagle that Diesel Exchange installed for him the best it would ever do is 450# on any cylinder it was a bear to start in cold weather but ran good with normal power come to find out they used 17:1 pistons
Geoff
« Reply #77 on: October 10, 2012, 09:24:14 AM »
I got my DD Field Service manual out and looked at compression readings for a V-71 N engine:
Compression is taken with engine running.
Compression at sea level 600 rpm 565 psi for a new engine, Minimum for a used engine is 515 at 600 rpm.
For a turbo engine with the lower compression pistons the readings are 475 and 425, respectively.
I know from personal experience and many compression tests that once you get at or below 500 psi at idle the "N" Detroit engine gets hard to start.
--Geoff
Geoff
'82 RTS AZ
« Reply #78 on: October 10, 2012, 06:34:57 PM »
They won't go 500 lbs at 2500ft I know that much lol
Dlsnow
dave
dave
« Reply #79 on: October 11, 2012, 07:14:11 AM »
Well...as usual...life happens...
compression test kit shows up...
pouring rain and I cant work on the bus
Cant wait for this weekend.
FWIW my experience starting is
50 deg or higher and the bus starts right up (3 or 4 seconds on starter) especially if it was run the last day...rough idles for 10 seconds then smooths out
40 and it is usually 3 reps of 6-10 seconds...rough idles for a minute then smooth
PO said he has had only straight 40 for oil and convinced me the same...only straight 40
1972 MCI7 8v71 converted - 1kw solar on roof
B_K
« Reply #80 on: October 11, 2012, 08:47:38 AM »
Dave there is a solution for working on buses outside in the rain, snow, extreme sun/heat.
I use an "EZ Up" Awning. I use it here outside the shop, & I take it with me on road service calls. Just put it up next to the bus where your going to be working and walla you have a "carport" to work under.
They don't cost that much and fold up nicely for storage and can be used for other uses too!
I think that EVERY BUSNUT should have one.
Dlsnow
dave
dave
« Reply #81 on: October 12, 2012, 05:07:54 AM »
Well BK if all goes well i will use the money i saved for a cylinderkit and pickup an EZ-UP
« Reply #82 on: October 14, 2012, 09:12:09 AM »
You have been quite for a few days any updates ?
Geoff
« Reply #83 on: October 14, 2012, 06:20:53 PM »
The Harbor Frieght diesel compression tester does not have a dummy injector for a a 2-stroke Detroit.
--Geoff
Geoff
'82 RTS AZ
« Reply #84 on: October 14, 2012, 07:45:15 PM »
Geoff, I have been wondering how he was going to make it work
The only thing I like about some 53 series (military) is they have glow plugs and you can remove the glow plugs and use about any type compression gauge
Dlsnow
dave
dave
« Reply #85 on: October 14, 2012, 08:46:27 PM »
Well - compression seems to check out - the HF kit is the 14 piece one http://www.harborfreight.com/14-piece-diesel-compression-tester-set-46800.html and it does have an adapter that is shaped like a v71 injector - followed BK's advice on WORK FAST (note don't burn the #*&$ out of your arms on the exhaust).
Compression was jumping around 300 - 330 with engine warmish (~160) and at fast idle
but...I found the injector wasnt really seated good - reseated and got a solid 480 - engine was cooling though - thinking cooler engine will get higher compression (is this logical?)
the compression gauge is filled with a thick fluid slowing its descent and letting me get a reading - not as nice as the ones with a "max reading" dial but workable.
I want to test it again as I broke rule 1 - Dont be in a hurry (visiting friends from out of town) and I think I can get the cover off faster now with a 12 point socket (was previously using a wrench - took forever to remove rocker covers).
here is the adapter pic -
So I checked the airboxes - no more parts showing up in there - scoped the cylinder again - still clean
installed new injector and reassembled -
no more smoke and a whole lot more power
hapilly moving down the road to tulsa OK - any busnuts in/around Tulsa?
heres the compression gauge pic
« Reply #86 on: October 14, 2012, 09:13:37 PM »
Not a bad looking kit for 119 bucks my Kent/Moore was a little more than that, a lot more lol good luck on your travels
Dlsnow
dave
dave
« Reply #87 on: October 14, 2012, 09:24:55 PM »
one issue I have is the tach reading - I dont have a tachometer
im not sure what my fast idle is set to either
but I assume with the compression reading I have in that hole I dont have valve issues
bus is running remarkably well
I will temp gun the exhaust to see if those readings are the same on each pair of cylinders after my run tomorrow
other than the new injector I didnt adjust the injector rocker as they all checked at 1.460
« Reply #88 on: October 15, 2012, 11:18:50 AM »
THAT WOULD HAVE BEEN CHOPPED LIVER'S <----who would be me>
WORDS OF ENCOURAGEMENT, BK SUGGESTED YOU TO BUY A TENT.
were i you..
1 startup and get engine up to temp...drive it around till 180 deg
2 shutdown
WORK FAST
I am guesssing it takes about 7000 posts before you become visable here.... Grin
B_K
« Reply #89 on: October 15, 2012, 12:05:19 PM »
were i you..
2 shutdown
WORK FAST
You would be correct!
Quote from: eagle19952
How would I know, I only have 40 posts here    Wink
Pages: 1 2 3 4 5 [6] 7   Go Up
