May 20, 2018, 11:09:30 AM *
Author Topic: VS2-8 transmission help  (Read 4197 times)
tanman496
« on: September 05, 2012, 09:32:15 PM »
My name is Mark, I bought a 1980 GMC  H8H649 about a month ago, The bus came with a manual transmission from GM someone installed a VS2-8 automatic transmission which is fine but , you have to shut the bus off to change gears from forward to revease. After looking high and low on the net noone seems to have a wiring diagram for the H8H649. I have one for a 1978 4905a bus but it dont show one with the VS2-8 trans as a option. can anyone help me wire this up , what parts will I need and where can I get them?? Thanks alot for reading Mark
Mark
tanman496
« Reply #1 on: September 09, 2012, 09:48:04 PM »
Mark
Scott Crosby
« Reply #2 on: September 10, 2012, 03:37:49 AM »
Why do you have to turn it off to switch from f-r?  Is it because it grinds and does not want to go into gear?  Has someone bypassed the neutral safety and you have to start it in gear?
61 GM Fishbowl TDH 4516 102" 35'
1947 GM PD 3751
www.busgreasemonkey.com
Scott Crosby
« Reply #3 on: September 10, 2012, 03:44:41 AM »
http://brandon314.wordpress.com/2011/08/12/vh-vs-series-service-manual/
1947 GM PD 3751
tanman496
« Reply #4 on: September 12, 2012, 08:51:21 PM »
Yes it does grind when you try to put into gear. And yes it will start in any gear so I guess the neutral safety switch is disconnected
Mark
Scott Crosby
« Reply #5 on: September 13, 2012, 06:26:22 AM »
That is a common problem.  The neutral safety switch is a great work around.  I have a similar trans the VH9, you have the better looking sister trans to mine.  I start in gear to avoid the grinding.  I can switch gears from F to R once the fluid is warmed up.  But I have to do it fast.  Out and into the other gear really fast.  I've never heard of a fix for the problem other than the workaround which you already have. Loren joplin said it had something to do with a hanging clutch pack that was a GM change up that had that negative result.  I don't know about that, I was also told that it might be a few other things too.  Just don't grind the gears, if it happens stop it right away.
If you find a fix, let me know....  I've asked, otherwise it's not to bad to live with it.  I avoid parking where I have to put it into reverse, and mostly just leave it in F
1947 GM PD 3751
pabusnut
« Reply #6 on: September 14, 2012, 06:25:10 PM »
I had a VS2-8 in my 5301 and had the same trouble.  I always started it in neutral until I had good air pressure.  Then I shut down-put in Forward, and restarted.  I could switch from F to R and back again if I did it quickly once the fluid was warmed up.
It was never a problem for me, and some days I wish I had the Automatic in my 4905, especially when trying to back in a campsite and not slip the wet clutch!
Steve Toomey
PAbusnut
Steve Toomey
PAbusnut
tanman496
« Reply #7 on: September 17, 2012, 05:31:18 PM »
well someone installed this transmission but never installed all the parts that go with it , like a shift switch and all the wiring that has to be hooked up so you have backup lights. Its a real pain to have to shut it off to change gears when your trying to turn the bus around.
Mark
Scott Crosby
« Reply #8 on: September 17, 2012, 05:41:06 PM »
My bus a 61 GMC didn't come with back up lights or any wiring for them.  I added them myself.
1947 GM PD 3751
« Reply #9 on: September 17, 2012, 09:33:12 PM »
tanman, you might want to look up Bill Gerrie over at BNO.
He knows an awful lot about these transmissions and might have a few ideas for you.
tanman496
« Reply #10 on: September 18, 2012, 02:35:48 PM »
Thanks Bus warrior I never heard of BNO Who are they?? do you have a number for them?
Mark
thomasinnv
Derrick Thomas
« Reply #11 on: September 18, 2012, 02:41:34 PM »
BNO is "the other board"
Sent from my PantechP9070 using Tapatalk 2
1998 MCI 102-DL3
Series 60 11.1/Alison B500
« Reply #12 on: September 18, 2012, 02:43:15 PM »
BNO, Bus Nuts On Line a forum like this almost the same they have some great GM people there
« Reply #13 on: September 18, 2012, 07:12:32 PM »
www.busnut.com
Click on the "BNO BBS" link in the LH column.
