March 19, 2018, 02:08:18 AM *
Author Topic: Dash Air  (Read 5136 times)
« Reply #15 on: August 03, 2013, 08:24:10 AM »
           Who makes the gas or diesel powered AC units for big trucks. They mount the engine n compressor on the frame of the truck and condenser on the back of the cab.
« Reply #16 on: August 03, 2013, 09:33:39 AM »
ThermoKing makes the Tripack that uses a 2 cylinder Diesel (2 cylinders are rough running) to power the A/C compressor that uses the existing truck evaporators to cool the cab.
Powertech uses a conventional generator to power a Dometic electric under bed A/C and heat.
There are numerous APU (Auxiliary Power Unit) made for trucks. Most have about a 14,000btu capacity for the A/C-which is the same as a roof top A/C.
Because of most APU's using a 2 cylinder and not much sound insulation, they are noisier then you would want to use in a campsite. In a noisy truck stop, not a problem. Good Luck, TomC
