May 24, 2018, 04:40:05 PM *
Author Topic: Now this is ironic... (air leak)  (Read 792 times)
thejumpsuitman
« on: September 26, 2012, 04:26:49 PM »
I took the Eagle to get her safety inspected and after passing I apparently blew out an air line on the way home...  So now that it has been declared "safe" it is not.  LOL.
It  blows out air from the rear behind the bogey wheel on the passenger side.  I got home safely but will need to investigate.  Builds pressure fine...  Only loses air when brake is pressed.  Any advice?
« Last Edit: September 26, 2012, 04:36:13 PM by thejumpsuitman » Logged
1986 Blue Bird Wanderlodge PT-40
DD 8V92TA, Allison HT748
Albemarle, NC
DMoedave
« Reply #1 on: September 30, 2012, 02:52:59 PM »
it most likely is a brake line since it only leaks whe n you apply brakes! block her up and put on the coveralls. look for a chafe point.
