April 22, 2018, 03:52:43 AM *
Author Topic: Williams air throttle part - Ebay?  (Read 3542 times)
Paladin
Dave Knight
« on: October 02, 2012, 07:25:30 PM »
What do you guys think of this? Still need pedal and modulator if memory serves but a start for the price?
http://www.ebay.com/itm/WILLIAMS-CONTROLS-WM-388-U1C1D-117888-MCI-BUS-COACH-AIR-THROTTLE-CONTROL-/180986701443?pt=Other_Vehicle_Parts&hash=item2a23a5e683&vxp=mtr
'75 MC-8   'Event Horizon'
8V71  HT740
Salt Lake City, Utah
Eagle Andy
Cowboy Coach
1968 Silver Eagle # 7481
« Reply #1 on: October 02, 2012, 07:48:48 PM »
That is a good start go for it  Grin I had to make  my bracket the is on that one.you will love it when you get it done.
« Reply #2 on: October 02, 2012, 07:57:07 PM »
That is a universal control you need the pedal to match fwiw Andy is good at installing those he did it right the 1st time
Eagle Andy
Cowboy Coach
« Reply #3 on: October 03, 2012, 04:17:43 AM »
Yes Clifford I did do it right the first time  Grin However I had you to thank  for that.  Roll Eyes
Cary and Don
« Reply #4 on: October 03, 2012, 09:48:30 AM »
Make sure that the pedal and the control BOTH have the same air pressure rating.  If not you will either have no throttle or a wide open throttle during application.  The part number on the housing will tell you. Experience speaking here.
Don and Cary
1973 05 Eagle
Neoplan AN340
« Reply #5 on: October 03, 2012, 04:20:19 PM »
It really is the best to buy the control that is made for the DD 2 strokes it mounts on top of the governor housing no brackets to make or linkage to figure out fwiw
Gary LaBombard
"Rustless Money Pit"
« Reply #6 on: October 04, 2012, 08:36:43 AM »
Don,
I just received a Williams Air Control foot treadle with the numbers (WM-453-B) on the body.  Two weeks ago I purchased the ebay listing of the modulator I will call it that mounts at the engine that is also mentioned in this thread above.  This is a very, very good looking modulator too I might add and the price is wonderful too.  I plan to get another just for kicks or in case needed on the road and have a spare for the price. The instructions for the modulator mounted on the engine says to use (60 psi) but I do not have any instructions for the foot treadle I just received today.  With the knowledge you now have in your opinion should I use a pressure regulator for 60 psi or use the full pressure to have control of the foot pedal for speed of the engine etc?  so with the information I have given you, would you recommend full air pressure of the 1/4" line or 60 PSI??  Also, would you run 3/8" or 1/4" line from the front of the bus to the back Governor modulator??
Thanks ahead of time
Gary
Gary
« Reply #7 on: October 04, 2012, 03:27:32 PM »
Better check it out for clearance Gary sometimes they work on a 05 without and modifications above the panel sometimes it takes a little fab work lol
