May 19, 2013, 10:09:08 PM *
Author Topic: For The Prevost Guys With 60 Series  (Read 1215 times)
« on: October 10, 2012, 07:20:53 PM »
Are any of you guys running a fuel cooler I guess it was a option on some models anyways mine had one but the fire damaged it and Prevost is very,very proud of that item is there a after market for the cooler
Living in Az I prefer to keep it cooler fuel adds hp (so I am told) then I worry about the piece of junk plastic for a fuel tank getting to hot any ideas
« Last Edit: October 10, 2012, 07:44:01 PM by luvrbus » Logged
Boomer
« Reply #1 on: October 10, 2012, 07:37:42 PM »
Standard, not optional either add or delete.  All our newer ones had it and when specing the coach there were no options on it as I remember Clifford.  I think it was mandated  by DDC.  Hell, there was so much stuff stacked on the radiator it was a wonder they ran cool (CAC, aux A/C condenser, fuel cooler).  You might try finding  someone running a hot engine and shoot the lines with an IR gun to see what they run I would not be surprised if everything would be OK to eliminate it.  You're worried about cooler fuel gaining more HP when you are running 650 hp, lol?
« Last Edit: October 10, 2012, 07:40:37 PM by Boomer » Logged
'81 Eagle 15/45
'47 GM PD3751-438
'65 Crown Atomic
Vancouver, WA USA
« Reply #2 on: October 10, 2012, 07:45:24 PM »
Somewhere in that area Boomer lol I been around the old 2 strokes so long when the fuel gets hot they kinda get sleepy around 4 in the afternoon on a hot day
« Last Edit: October 10, 2012, 08:00:26 PM by luvrbus » Logged
Boomer
« Reply #3 on: October 10, 2012, 08:42:22 PM »
Well, you could do like us old drag racers did 100 years ago, make a cool can with a coil of copper fuel line in it and filled with ice, lol.
'81 Eagle 15/45
'47 GM PD3751-438
'65 Crown Atomic
Vancouver, WA USA
B_K
« Reply #4 on: October 10, 2012, 10:57:41 PM »
Yeah Boomer that was done with road racers and roundy rounders too!
(PS from personal experience "dry ice" can cause worse problems like frozen fuel!)
Hard Headed Ken
« Reply #5 on: October 11, 2012, 05:08:15 AM »
Some related info I found on DDCSN
http://www.ddcsn.com/cps/rde/xbcr/ddcsn/3-ddecv-06a.pdf
Ken
stevet903
« Reply #6 on: October 11, 2012, 08:35:40 AM »
What model do you have?  Many of the H3s and XLIIs used part number 531422 as a fuel cooler.  Prevost wants $41.91 for it.  Steve
« Reply #7 on: October 11, 2012, 10:20:35 AM »
The one I have Prevost is asking over 500 bucks for it
B_K
« Reply #8 on: October 11, 2012, 03:59:53 PM »
Clifford maybe the "Prevost Prouds" have told Prevost who you are so they are giving YOU a special Prevost Proud price LOL!  Cheesy
« Reply #9 on: October 11, 2012, 04:25:03 PM »
You could use a Hayden cooler-just have to position it away from engine heat.  Good Luck, TomC
Mex-Busnut
« Reply #10 on: October 11, 2012, 05:26:16 PM »
Is there any advantage to adding a fuel cooler to a 6V92TA?
Jake brakes
« Reply #11 on: October 12, 2012, 12:10:02 PM »
There is advantages to adding a fuel cooler to any engine with just a single tank. Cooler fuel is denser, so you'll have more fuel injected-hence a bit more power then with hot fuel.  And since the fuel is what lubricates the fuel injectors, it can only be good.  Good Luck, TomC
B_K
« Reply #12 on: October 12, 2012, 04:00:10 PM »
Clifford I was speaking to "The Don" this afternoon and asked him about it.
He said for $500 bucks for the "Prevost part" he'd just use a "Hayden" cooler for about $40-$50 and said with their new "stack-able" design you can make it any size you want and for another $100 you could even put a fan on it!
« Reply #13 on: October 12, 2012, 07:43:29 PM »
Mine does have a fan BK, shroud and 24 v motor all the plastic melted I think I am going with 50 dollar cooler
Uglydog56
« Reply #14 on: October 12, 2012, 09:09:36 PM »
How much room do you have to work with?  Get the smallest radiator you can find at the junkyard - will already have a fan on it.
Rick A. Cone
Silverdale, WA
66 Crowny Crown "The Ark"
