May 24, 2013, 03:01:50 AM *
Author Topic: fried clutch  (Read 855 times)
ronnie32567
« on: October 10, 2012, 08:02:46 PM »
1972 Eagle 8V71, 4sp man trans.  Anyone know the easiest way to install new clutch. Any info is great.
1972 Eagle conversion 8-71 dd, 4 diesel pickups, diesel tractor , diesel bulldozer  Crestview, Florida
B_K
« Reply #1 on: October 10, 2012, 11:02:02 PM »
Yup take it to Clifford aka Luvrbus aka YODA!
« Reply #2 on: October 11, 2012, 06:34:18 AM »
They look harder than they are it will take you about 5 hrs people just swing the transmission and some drop it works better with 2 people
Do you have any idea what clutch is installed now several options on a Eagle for a clutch it will cost you from 500 bucks up to a 1000 bucks depending which way you choose too go
ronnie32567
« Reply #3 on: October 12, 2012, 03:03:13 PM »
No idea about what type of clutch is in it now.  A local busnut that I met through this forum says he has an 8v71 with man trans that came out of a big military truck and that I could have the clutch out of it. I wonder if it is the same type clutch and would fit the eagle.
« Reply #4 on: October 12, 2012, 04:32:46 PM »
i don't know but seriously doubt it.... Undecided
« Reply #5 on: October 13, 2012, 07:48:14 AM »
It's easy to tell to just pull the bottom cover and see if it has been converted over from the pull type to a mushroom type if you live close to Tulsa I have a friend that has a fairly new button type for a Eagle I can send you his number he will probably sell it cheap,cheap
B_K
« Reply #6 on: October 13, 2012, 08:09:34 AM »
Clifford I think he's in FL.
ronnie32567
« Reply #7 on: October 13, 2012, 05:23:56 PM »
Mr Clifford, yes I live way back in the woods in florida, but UPS does run every blue moon or so. I really don't know what to look for as to a pull type or mushroom. If the clutch from the military truck wont work I'll contact you for your friends number. I have one other problem with the engine, it was completely rebuilt by Winnibego 34,000 miles ago. runs like a singer sewing machine and does not smoke at all, but when I shut it off it pours oil like crazy from the drivers side of the engine, someone told me that there was a pipe that stops up and makes it leak oil.
