February 25, 2018, 03:38:19 PM *
Author Topic: Water heating diagram. Will it work?  (Read 6829 times)
Chaz
4108, 8V71 w/auto .
« Reply #15 on: November 15, 2006, 01:08:31 PM »
Thanx Jim,
  I appreciate that.
  I try to live by my signature line:
  "Imagination is more important than knowledge" - Albert Einstein
But I would rather pay the price than somebody else.
Chaz
Homegrowndiesel
Vegetable oil, Rudolf Diesel's original fuel
73-05 Eagle
« Reply #16 on: November 16, 2006, 06:08:05 PM »
Not Bad Chaz, close to everything you will need? Smiley
WOW alot of good advise, Grin concider all. It is always nice to get interesting opinions and good advise. Huh
OK now MINE, everybody has one, OPINION which I hope will also be good advise. Wink
As noted missing generator circuit, input(take asprin).  Cool
Most all diesel boilers are ordered with coolant pump.
As expressed, when idiling you will need it.
Good advise on the supply and return manifold ( use regular on-off valves)3 ways are expensive.
Good suggestions on the summer and winter valve.
As noted no need to close both, supply and return.
Think, Detroit supplying manifold, generator supplying manifold, webasto supplying manifold.
Of course if you have supply you need return (cold in your drawing).
Some circuits can be run in parrallell and some can be series depending on use.
Full 3/4" minimum, (prefer1" pex) from and to the manifolds. 3/4" or 1/2" pex or heater hose from there, depending on btu of the heat exchanger and load. Shocked
" It is beautiful for an engineer to shape and design the same way that an artist shapes and designs. But whether the whole process makes any sense, whether men become happier - that I can no longer decide."
        Rudolph Diesel
Grand Pops Saying was " There is technology today to do anything the human mind can imagine." I live by that.
I like,
                                    "    WHO SAID CAN'T?
                            someone is always doing something
                           Someone else said was impossible.       "
                                                               unknown
Bill
Aerodynamic Eagle & MCI 102a3, 102d3 and NABI series 50 transit. Busnut x4
