April 21, 2018, 10:17:53 PM *
Author Topic: Loc-tite on corner drive bolts?  (Read 6207 times)
« on: November 14, 2006, 11:40:21 AM »
I lent my corner drive to the local hockey team while they were waiting for a new one to arrive.  The guys that pulled it out said the bolts were *)$%# tight.  When I put it back in should I use loctite on them?  I know - - look in Da Book but Da Book is in Da Bus which is in Da COLD COLD shop.
« Reply #1 on: November 14, 2006, 12:06:42 PM »
Corner drive?
Is that a Canadian term?
What's the American equivalent?
Or is this headache really something I should be concerned about?
mikeH8H-649
« Reply #2 on: November 14, 2006, 12:45:25 PM »
I also am curious as to what a corner drive,must have some other name or just something new to me   Mike
« Reply #3 on: November 14, 2006, 04:00:55 PM »
Corner drive?
Dunno what the 'murican equivalent would be & I don't know what else you would call the "right angle gear drive mechanism" that the radiator fan mounts to.  What do you call it?
« Reply #4 on: November 14, 2006, 04:28:02 PM »
Do you mean the miter box?
jjrbus
MCI5C/N Ft Myers FL
« Reply #5 on: November 14, 2006, 05:15:19 PM »
Miter box? Thats something you cut wood with!  Bob used the wrong terminology it is actually a dual corner box.
Stan
« Reply #6 on: November 14, 2006, 05:23:31 PM »
Nothing wrong with using Loc-tite on any bolt that you want to stay in place. There are different kinds for bolts that can be taken out with a lot of torque and and for bolts that require heat to break the bond.  Use whatever kind suits your fancy for you application.
NEWELL in South Carolina
« Reply #7 on: November 14, 2006, 08:34:34 PM »
Wat Stan said . . . PLUS Now is a good time to use NEW bolts to put it back on. I'd consider grade 8 bolts as it would be better to over kill the hardware now rather than have them shear off after you loctite-ed them in place & your trip is interupted.
« Reply #8 on: November 16, 2006, 11:54:17 AM »
Thanks for the confirmation guys.  Grade 8 fine thread with loctite it is then.  Weather warmed up today so it might even happen tonight.
« Reply #9 on: November 16, 2006, 06:00:49 PM »
Loctite comes in several forms of strength required. I don't know the numbers, but some require the bolt or nut to be heated up before it can be removed. Once apllied that is the only way to take it apart. There are several that are removable, no heat involved to loosen. Just depends on what the need is. There is red, blue and green in color, to visually see which one you are using.
Hope this helps in some way.
« Reply #10 on: November 16, 2006, 06:48:56 PM »
Be careful with Red Loctite.   It's a PIA to remove anything locked with that stuff.  Think of it as permanent.
I just wrote a book on why to not use it on a bell housing and then notice that a "corner drive" is on the other end of the engine.   Duh!  I deleted that...
Blue Loctite is the best for keeping bolts in place.  New lock washers and hardware go a long ways too!
Best, JR]
HITH do you work on a cold bus?  Shocked
« Last Edit: November 16, 2006, 07:02:42 PM by NJT5047 » Logged
« Reply #11 on: November 16, 2006, 08:06:46 PM »
I believe the two ended right angle drive coming from the DD crankshaft and connecting to the factory A/C on one side and the radiator fan on the other side is more properly identified as the miter (mitre?) box, not a corner drive.
Stan
« Reply #12 on: November 17, 2006, 06:20:22 AM »
Note that Bob said <what else you would call the "right angle gear drive mechanism" that the radiator fan mounts to.  What do you call it?>
I don't remember what kind of bus that Bob is working on, but if the fan mounts on the box, it is not the miter box like on the back of an Eagle. The GM 4501 used a right angle gear box with a shaft  drive on the input and the fan mounted directly on the output shaft. If the correct name is so important, maybe somebody with a 4501 parts book can look it up.
« Reply #13 on: November 17, 2006, 07:10:28 AM »
Stan -
Ask & ye shall receive, direct from a Scenic Shop Manual/Parts Book:
GBK-9850  BOX, gear (1:1 ratio) (FAN DRIVE ONLY)
« Reply #14 on: November 17, 2006, 02:51:46 PM »
That is exactly the situation although it is on a 1981 Prevost.  This thread has deteriorated severely and really hasn't dealt with my question at all.  My concern was vibration on the "corner drive" loosening the bolts and whether or not it would be wise to use loctite or more specifically whether there was any reason NOT to use loctite.  I've come to my own conclusion.
And contrary to what I posted above I will NOT be using Gr 8 bolts.  This is just my opinion but I think I will stick to what was there originally which was Gr 5 fine thread.  If there are any issues about brittleness in conjunction with the vibration from the fan my personal opinion is that the Gr 5 will be a better choice.
And in answer to Mr Lynch - you work quickly, with frequent trips to the house, with a diesel fired shop heater or you wait for a warm day.  Of course warm days could be in short supply until late April so that really isn't a good option.
« Last Edit: November 17, 2006, 02:53:42 PM by bobofthenorth » Logged
