June 20, 2018, 12:27:17 PM *
Author Topic: That wasn't so bad.  (Read 1537 times)
chazwood
« on: November 26, 2012, 03:51:00 PM »
1) Just pulled the driver tag axle apart and replaced sleeves washers and split washers,
2) pulled all the connecting rods in the back and replaced worn bushings.
3) cut out all the rust along bottom of side skin and welded in new steel, prepped, primed and painted.
4) replaced front wheel well skins with 3/16 aluminum Plate. Had holes sandblasted into them on both sides.
5) replaced front bearings on pass. Side.
6) replaced front brake pads. (this bus was converted over to disk brakes)
7) Took out most of the seats and built in 8 bunks.
Cool replaced back sway bar and tie rod ends. (backorderd)
9) swapped around four fuel injectors (was running on only 5 cylinders) now she rips on 6!
10) replaced the fabric on the front window divider (very easy)
11) welded in a few bits of steel where rust had chewed a hole.
All in the last 3 weeks with a tour of new England stuck in there.
Having fun.
1983 Eagle Bus Model 10
6V92
Thekempters.com
chazwood
« Reply #1 on: November 26, 2012, 04:01:46 PM »
I think I'll go tell my wife I just saved her $15,000 and now can I have that boat and motor?
6V92
Thekempters.com
Geoff
« Reply #2 on: November 26, 2012, 04:35:22 PM »
I'm glad you enjoy the work-- that is just the begining.  I rebuilt my bus from bottom to top, and front to back so I know what is involved.  The only thing I didn't do myself was paint it.
--Geoff
Geoff
'82 RTS AZ
chazwood
« Reply #3 on: November 26, 2012, 06:13:12 PM »
Didn't paint? That's the easy part!
6V92
Thekempters.com
