May 21, 2013, 09:56:58 PM *
Author Topic: air pressure blow off valve noise/sound has changed  (Read 390 times)
bansil
« on: November 28, 2012, 04:40:41 PM »
I noticed this past weekend that instead of a nice "crisp" pop once pressure was reached,I get a "slower" bleed off sound.
I crawled under bus and noticed the valve is kind of grimy,can I just take it apart and clean it or ??
Pressures looked the same as normal on the gage,it just sounds "sick"
Doug
Mnt City TN
Utahclaimjumper
« Reply #1 on: November 28, 2012, 04:57:40 PM »
 If your talking about an "air dryer", they need service on a regular basis and it takes a rebuild "kit".>>>Dan
Utahclaimjumper
 EX 4106 (presently SOB)
Cedar City, Ut.
Dave5Cs
« Reply #2 on: November 28, 2012, 09:10:10 PM »
Drop the bottom out and take the purge valve apart and clean it. Replace the dessicant cartridge NAPA 68.00 and it has a new check valve in it so don't order an extra one.
Dave5Cs
bansil
« Reply #3 on: November 29, 2012, 02:03:43 AM »
Thank you
Doug
Mnt City TN
HB of CJ
« Reply #4 on: November 29, 2012, 11:38:36 AM »
Did it make its sound/duration change during hot, dry weather, or has it started doing it now that things are very cold and wet?  Yep...moisture.  My old Crown had an separate air dryer cartridge filture thing that was supposed to changed out.  HB of CJ (old coot)
