January 21, 2018, 02:41:50 PM *
Author Topic: gm paint  (Read 2478 times)
jimsflx
« on: December 17, 2012, 03:22:52 PM »
can you strip paint off the bottom half of a 4106?  will it hurt the siding? and what do you use to strip it whith. thanks for your imput. jim
jim&roenie seagraves sebring fl. 4106-3083
Cary and Don
« Reply #1 on: December 17, 2012, 05:13:13 PM »
There is a paint stripper made for airplanes that works really well.  It's pretty expensive but makes the job a lot easier than trying to sand it off.
Don and Cary
1973 05 Eagle
Neoplan AN340
Utahclaimjumper
« Reply #2 on: December 17, 2012, 05:50:13 PM »
Its called "Aircraft stripper" and it will not harm the aluminium surface of your coach. Be prepared to find body filler under some of the paint,, these busses get banged up on the lower half and is the normal reason to paint it..>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
LowTide
« Reply #3 on: December 18, 2012, 03:32:59 PM »
You may want to check with a company that soda blast's, look for sand blasting companies, some specialize in soda blasting. I would think that may be cheaper than the price of aircraft stripper...
« Last Edit: December 18, 2012, 03:39:48 PM by LowTide » Logged
Mike and Lori
Sunny Phoenix Arizona
"1973 MCI MC-7 Challenger"
"Just Misbehavein' "
"A nation of sheep helps breed a government of wolves"
Dave5Cs
« Reply #4 on: December 18, 2012, 03:44:01 PM »
I have heard of a guy on another board that used Brake fluid in a spray bottle.
Dave5Cs
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
Utahclaimjumper
« Reply #5 on: December 18, 2012, 05:37:55 PM »
Ask the "Red Rider",, we recently stripped the bottom half of his 06 and repainted after some extensive body work.>>>Dan
« Last Edit: December 19, 2012, 10:42:48 AM by Utahclaimjumper » Logged
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
